Dallas CRC8 Routines
Results 1 to 24 of 24
    Jan 2004
    Grand Lake O' Cherokees USA
    Default Dallas CRC8 Routines
    Three different PBP programs to calculate the Dallas 8bit CRC.
    ' PIC16F628
    ' These routines are documented in Dallas Semiconductor Application Note 27
    ' Understanding and Using Cyclic Redundancy Checks
    ' This program contains three subroutines for calculating the Dallas 1Wire 8bit CRC.
    ' The computationally intensive short version is called CRC8. Use this one when
    ' you don't have enough PIC memory to store the table version (approx 270 words)
    ' and can afford the processing time.
    ' The table version CRC8LU is computationally fast since it works on byte at a time
    ' rather than bit at a time as CRC8 does.
    ' The Assembly Language version of the computationally intensive version is CRC8AL.
    ' Times per 8 bit CRCByte:
    ' CRC8LU 35usec
    ' CRC8AL 115usec
    ' CRC8 260usec
    @ DEVICE XT_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE LVP_OFF
    CMCON = 7
    TestBit var Bit ' CRC8
    TestByte var Byte ' CRC8AL
    CRCData var Byte ' CRC8 & CRC8LU & CRC8AL
    CRC var Byte ' CRC8 & CRC8LU & CRC8AL
    I var Byte ' CRC8 & CRC8AL
    ' Test data
    CRCData = $02
    CRC = 0
    'Gosub CRC8
    'Gosub CRC8LU
    Call CRC8AL
    ' Test CRC should be $BC
    ' ********** Subroutine CRC8 **********
    ' PBP Version not using lookup table
    ' Expects CRC starting value and CRCData
    ' CRC will be cumulative unless reset externally
    ' Gives ending CRC value and destroys CRCData
    ' Uses I-Byte, TestBit-Bit, CRC-Byte, CRCData-Byte
    CRC8:
    For I = 0 to 7 ' Do for all 8 bits in data byte
    TestBit = CRC.0 ^ CRCData.0 ' XOR bit0 of data byte and crc
    CRCData = CRCData >> 1 ' Position data byte for next bit test
    If TestBit = 0 then Shift ' If test bit not set, just shift CRC
    CRC = CRC ^ $18 ' If set, account for EXOR feedback
    Shift: ' Shift right the CRC byte
    CRC = CRC >> 1 ' CRC bit 0 to bit bucket
    CRC.7 = TestBit ' Test bit rotates into CRC bit 7
    Next I
    ' ********** Subroutine CRC8AL **********
    ' Assembly Language version of Dallas CRC8 calculator
    'CRC will be cumulative unless reset externally to routine
    ' Gives ending CRC value in CRC and destroys CRCData
    ' Uses I-Byte, TestByte-Byte, CRC-Byte, CRCData-Byte
    _CRC8AL ; Dallas CRC8 Assembly Language PIC16F628
    MOVLW 8
    MOVWF _I ; Do this for all 8 bits of CRCByte
    CRCLOOP
    MOVF _CRC,0 ; Put CRC into W
    XORWF _CRCData,0 ; XOR CRC with CRCData
    MOVWF _TestByte ; Put results in TestByte
    RRF _TestByte,1 ; Shift TestByte.0 into Carry bit
    BTFSS STATUS,C ; If Carry = 1, account for EXOR feedback gates
    GOTO CRCSHIFT ; Otherwise just shift CRC and CRCByte
    MOVF _CRC,0 ; Get latest copy of CRC
    XORLW 0x18 ; XOR with 18Hex
    MOVWF _CRC ; Keep a copy of results
    CRCSHIFT
    RRF _CRC,1 ; Rotate CRC incorporating carry
    RRF _CRCData,1 ; Rotate CRCData, carry shifts in but not important
    DECFSZ _I,1 ; Keep track of #times through loop
    GOTO CRCLOOP ; Go to start if not looped through the 8 bits
    RETURN ; Return if all 8 bits analyzed
    ' ********** Subroutine CRC8LU **********
    ' Expects CRC at some starting value with data to CRC
    ' passed in CRCData.
    ' Uses CRCData-Byte, CRC-Byte
    CRC8LU:
    CRCData = CRCData ^ CRC
    Lookup CRCData, [0,94,188,226,97,63,221,131,194,156,126,32,163,253, 31,65,_
    157,195,33,127,252,162,64,30,95,1,227,189,62,96,13 0,220,_
    35,125,159,193,66,28,154,160,225,191,93,3,128,222, 60,98,_
    190,224,2,92,223,129,99,61,124,34,192,158,29,67,16 1,255,_
    70,24,250,164,39,121,155,197,132,218,56,102,229,18 7,89,7,_
    219,133,103,57,186,228,6,88,25,71,165,251,120,38,1 96,154,_
    101,59,217,135,4,90,184,230,167,249,29,69,198,152, 122,36,_
    248,166,68,26,153,199,37,123,58,100,134,216,91,5,2 31,185,_
    140,210,48,110,237,179,81,15,78,16,242,172,47,113, 147,205,_
    17,79,173,243,112,46,204,146,211,141,111,49,178,23 6,14,80,_
    175,241,19,77,206,144,114,44,109,51,209,143,12,82, 176,238,_
    50,108,142,208,83,13,239,177,140,174,76,18,145,207 ,45,115,_
    202,148,118,40,171,245,23,73,8,86,180,234,105,55,2 13,139,_
    87,9,235,181,54,104,138,212,149,203,41,119,244,170 ,72,22,_
    233,183,85,11,136,214,52,106,43,117,151,201,74,20, 246,168,_
    116,42,200,150,21,75,169,247,182,232,10,84,215,137 ,107], CRC
    ' PBP only handles 255 constants in the list (256 for 18Cxxx). Since table is
    ' indexed starting at zero, special case for $FF (256th element).
    If CRCData = $FF Then
    CRC = 53
    EndIF
    Tom
    If I used this line of code:
    owin portb.7, 0, [temp.byte0,temp.byte1,SKIP 6,crc_value]
    Would the calculated CRC be the same value as crc_value?
    Jan 2004
    More than likely no.
    You don't state which and I may not be familiar with the 1 wire device you are using but normally you would not be able to skip any characters it transmits. They would all need to be received and included in the CRC calculation. You will need to read the data sheet for the 1 wire device you are using to see what all is included in the CRC total.
    To get that total feed each byte into the CRC routine, The CRC will be calculated and after all bytes that the manufacturer has included in the CRC total have been passed trough it, the CRC should be the same as the CRC received from the 1 wire device.
    Tom
    Tom
    I actually working with the DS18S20 chip. From what I'm reading though it sounds like I calculate the CRC from the bytes read. Is this correct?
    Jan 2004
    I am not familiar with the DS18S20 but a quick look at the data sheet shows the CRC is calculated by reading all 8 bytes of the scratchpad memory, running them through the CRC routine and comparing its output to the 9th byte read from the scratchpad which is the CRC value generated by the DS18S20. See example 3 in the datasheet.
    Tom
    I think I can now safely say I'm completely lost as this is making no sense to me. Do I calculate the CRC for each bit using bit0 ^ bit1... and then XOR all the bytes one at a time or do I just XOR the bytes themselves? Please excuse my lack of understanding as this is all new to me.
    Jun 2007
    Default Re: Dallas CRC8 Routines
    Found an error in the CRC8LU subroutine when validating CRC byte after doing a 1-wire search.
    A CRC of $F0 on a device returns an error.
    This is because of a typo in Tom's code, the value 140 highlighted in red in the quote below is incorrect.
    From the table of Example 3 in Dallas AN27, the value here should be 240.
    Norbert
    Quote Originally Posted by Tom Estes View Post
    CRC8LU:
    50,108,142,208,83,13,239,177,140,174,76,18,145,207,45,115,_
    CRC = 53
    EndIF
    Dec 2010
    found 2 more typos for total of 3...
    line with 35,125,159,193,66,28,"154", Dallas has 254
    line with 101,59,217,135,4,90,184,230,167,249,"29", Dallas has 27
    line with 50,108,142,208,83,13,239,177,"140", but Dallas example is 240 (as noted above)
    Aug 2005
    Michigan, USA
    Has anyone ever converted Scott Dattalo's method (1-Wire Polynomial) to PBP?
    ;  Scott Dattalo's version (20 words, 23 cycles per byte)
    crc_8
            xorwf   CRC,F           ;
            clrw                    ;
            btfsc   CRC,0           ;
            xorlw   0x5E            ;
            btfsc   CRC,1           ;
            xorlw   0xBC            ;
            btfsc   CRC,2           ;
            xorlw   0x61            ;
            btfsc   CRC,3           ;
            xorlw   0xC2            ;
            btfsc   CRC,4           ;
            xorlw   0x9D            ;
            btfsc   CRC,5           ;
            xorlw   0x23            ;
            btfsc   CRC,6           ;
            xorlw   0x46            ;
            btfsc   CRC,7           ;
            xorlw   0x8C            ;
            movwf   CRC             ;
            return                  ;
    It seems like a pretty good compromise between size and performance.
    Regards, Mike
    If your concern is size and speed, why not use it as is with he addition of _ before CRC variable (_CRC)?
    I think it will work just fine.
    Aug 2005
    Michigan, USA
    Hi Ioannis:
    Since the Dattalo method wasn't mentioned in the thread, I simply wanted to pass it along, hoping it might be useful or helpful to PBP users. I'm afraid I don't know how you would implement it in PBP.
    While I've tried all of the methods discussed in this thread in the past, now days in my C programs I use bit level cumulative CRC built into my low level 1-Wire read/write bit driver. Total cost for doing it this way is 8 words of program memory, 1 byte of RAM, and 0 cycles processing overhead since the CRC code executes during a portion of the delay required to fill out the 60 usec read slot timing.
    Cheerful regards, Mike
  1. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 22:01
  2. dallas ibutton to pics
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 12:55
  3. Dallas 1-wire search Routine
    By jimbab in forum Code Examples
    Last Post: - 7th April 2006, 16:14
  4. Dallas Semiconductor Components Serial Numbers
    By ideaman234 in forum General
    Last Post: - 27th February 2006, 22:17
  5. Dallas CRC16 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 16th May 2005, 15:29
