ASCii To HEX?
Results 1 to 6 of 6
Thread: ASCii To HEX?
    OK
    Default ASCii To HEX?
    I'm working with an ELM327 OBD II Interpreter. The serial data is in the form of ASCii, intended to communicate with a PC Serial Port (yea, from a decade ago). If I send Request "01 05" (for Coolant Temp) it has to be in the form of ASCii. The Response would begin "41 05" then the value, all in ASCii. This means the first received byte is the upper nibble of the first Hex character, the second byte the lower nibble, and so forth. The PBP3 Reference Manual lists a HEX Modifier. The example leaves lots of ambiguity as to how it should be used. I am open to any suggestions on how to structure the "unraveling" code.
    Default Re: ASCii To HEX?
    to parse a variable number of hex2 chars I use this
    where U_RXBUFF[] contains the string to be parsed
              k                 contains the length of the input string
              STR_inx       contains the length of the OUTPUT string
              txbuff[]        contains the PARSED the OUTPUT string
    get_data:
        STR_inx=0
        k.0=0   ;must be even
        while  k
            ARRAYREAD  U_RXBUFF ,[SKIP ((STR_inx+1)<<1),hex2 txbuff[STR_inx] ]
            'Debug "k ",#k,9,#STR_inx,9,hex txbuff[STR_inx],13,10
            STR_inx=STR_inx+1
            k=k-2
        wend
    IF your fomat is fixed just
    serin2 .... [hex2 var1,hex2 var2,.........]
    OK
    Here is what I came up with today:
    Grab_ELM:
        IF Ebit = 0 THEN                            ;Indicates 1st Nibble ASCii Character
            Ebyt0 = RCREG1                          ;Load Upper Nibble into Ebyt0
        ELSEIF Ebit = 1 THEN                        ;Indicates 2nd Nibble ASCii Character
            Ebyt1 = RCREG1                          ;Load Lower Nibble into Ebyt1
        TOGGLE Ebit                                 ;Set Up to Load Lower Nibble, or Upper Nibble of Next Character
        IF Ebit = 1 THEN                            ;Just Loaded Upper Nibble, Still Need Lower Nibble
    @   INT_RETURN
    ;Combine HEX[Ebyt[0], Ebyt[1]]
            IF (Ebyt0 => $30) AND (Ebyt0 <= $39) THEN   ;Characters 0 >> 9
                ElmIn = (Ebyt0 - $30) << 4          ;Shifts to Upper Nibble
            ELSEIF (Ebyt0 => $41) AND (Ebyt0 <= $46) THEN  ;Characters A >> F
                ElmIn = (Ebyt0 - $37) << 4          ;Shifts to Upper Nibble
            IF (Ebyt1 => $30) AND (Ebyt1 <= $39) THEN   ;Characters 0 >> 9
                ElmIn = ElmIn + (Ebyt1 - $30)       ;Adds to Upper Nibble
            ELSEIF (Ebyt1 => $41) AND (Ebyt1 <= $46) THEN  ;Characters A >> F
                ElmIn = ElmIn + (Ebyt1 - $37)       ;Adds to Upper Nibble
        IF (ElmIn = $0D) OR (ElmIn = $20) THEN      ;Carriage Return or Space
    @   INT_RETURN                                  ;Ignore & Return
        ELSEIF (ElmIn <> $0D) AND (ElmIn <> $20) AND (ElmIn <> $3E) THEN
            Eval[ElmCt] = ElmIn
        ELSEIF ElmIn = $3E THEN                     ;">", End Of Transmission
            ELM_Rec = 0                             ;Can now send next Request
            ElmCt = 0                               ;Next BYTE In = New
            ElmDat = 1                              ;Must Decipher Eval[x]
            Ebit = 0                                ;Ensures 1st Character Loads into Ebyt0
    @   INT_RETURN                                  ;Return
        ElmCt = ElmCt + 1                           ;Will Load Next Character
    At least I have variables to work with in a Hex format. From there I have other subroutines to dissect the content.
    Aug 2003
    I don’t think there’s any modifier that would pull out one byte being represented as a pair of bytes.
    There’s no neat way to deal with ASCII, but everything after the first return could be a part of the main program though.
    The main program knows by the state of Ebit when it’s supposed to act on the input just as the code above does.
    OK
    Not sure if there's a short cut, but the code I posted is working.
    Aug 2003
    Generally, it’s very beneficial for interrupts to be as short as possible.
    I’m not sure how BASIC interrupts work.
    Working is the main thing
  1. hex dec ascii
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 11th February 2015, 21:11
  2. Hex to Ascii to Decimal
    By khoog in forum mel PIC BASIC Pro
    Last Post: - 31st July 2009, 05:27
  3. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 21:09
  4. Converting ASCII to HEX
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 27th September 2006, 10:21
  5. ascii characters to hex
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 04:06
