18F26K42 TMR1 Interrupt troubles
Results 1 to 6 of 6
Threaded View
  1. #3
    Default Re: 18F26K42 TMR1 Interrupt troubles
    your code would toggle led @32mS intervals , its a bit hard to see .
    I can't compile pbp3 for this chip but can say that these settings work in xc8
        CONFIG FEXTOSC = OFF
        CONFIG RSTOSC = HFINTOSC_64MHZ
        CONFIG CLKOUTEN = OFF
        CONFIG PR1WAY = OFF
        CONFIG CSWEN = ON
        CONFIG FCMEN = OFF
        CONFIG MCLRE = INTMCLR
        CONFIG PWRTS = PWRT_OFF
        CONFIG MVECEN = OFF
        CONFIG IVT1WAY = OFF
        CONFIG LPBOREN = OFF
        CONFIG BOREN = OFF
        CONFIG BORV = VBOR_245
        CONFIG ZCD = OFF
        CONFIG PPS1WAY = OFF
        CONFIG STVREN = OFF
        CONFIG DEBUG = OFF
        CONFIG XINST = OFF
        CONFIG WDTCPS = WDTCPS_31
        CONFIG WDTE = OFF
        CONFIG WDTCWS = WDTCWS_7
        CONFIG WDTCCS = LFINTOSC
        CONFIG BBSIZE = BBSIZE_512
        CONFIG BBEN = OFF
        CONFIG SAFEN = OFF
        CONFIG WRTAPP = OFF
        CONFIG WRTB = OFF
        CONFIG WRTC = OFF
        CONFIG WRTD = OFF
        CONFIG WRTSAF = OFF
        CONFIG LVP = OFF
        CONFIG CP = OFF
    'Defines, Includes, and Constants-----------------------------------------------
    DEFINE OSC 64                                   ' Calibrate PBP to 64MHz clock
    OSCFRQ = 8                              ' Set system clock to 64MHz internal
    OSCCON1 = $60
    on interrupt goto INC_TICK
    'Direction----------------------------------------------------------------------
    TRISA.1 = 0
    'Alias---------------------------------------------------------------------------
    LED    VAR LATA.1
    'Variables----------------------------------------------------------------------
    'Initialize Registers----------------------------------------------------------------------
    Initilize:
        ANSELA   = 0                      ' Set digital
         LED = 0
        INTCON0.7 = 1                                      'Enable global int
        T1CON = $35                                          'Prescale 1:8; enable the TMR1
        T1CLK = 1                                           'Clock Source Fosc/4
        PIR4.0 = 0                                             'Clear the Int flag
        PIE4.0 = 1                                             'Enable timer int
                                            'Start the timer
    C0UNTER VAR BYTE
    'Code---------------------------------------------------------------------------
        pause 1
        Goto Main
    '----- INTERRUPT CODE -------------------
    Disable
    INC_TICK:
             COUNTER=COUNTER+1
             IF COUNTER==31 THEN
             LED=!LED           ;TOGGLE LED ONCE PER SEC
             COUNTER=0
             PIR4.0 = 0
             Resume
    enable
  1. 12F683, TMR1 and ON INTERRUPT revisited
    By AvionicsMaster1 in forum PBP3
    Last Post: - 17th September 2013, 20:07
  2. Difficulty toggling LED with TMR1 overflow interrupt
    By jgjgjg in forum mel PIC BASIC Pro
    Last Post: - 30th July 2012, 12:17
  3. How to set Tmr1 to interrupt every 5 seconds
    Last Post: - 3rd December 2008, 04:51
  4. TMR1 100Hz Exactly Interrupt Routine
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 15th February 2007, 06:51
  5. TMR1 interrupt question
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 15th February 2006, 04:02
Members who have read this thread : 4
