Eeprom Word Addressing
Results 1 to 9 of 9
    Simon Brodeur's Avatar
    Simon Brodeur Guest
    Default Eeprom Word Addressing
    I'm trying to write 16bit values from an accelerometer to a 256K external 12C EEPROM. To values should be turning around 1000. . I have some problem reading and/or writing the values.
    I use the I2CREAD and I2CWRITE commands,with:
    cbit = %1010000
    When I read result, on the serial communicator, it looks of this:
    1024
    64367
    1016
    63290
    1032
    62986
    I think the problem is the address variable
    When I write word, in the form like:
    I2CWRITE SDA,SCL,cbit,address,[word]
    Will I have to increment address by 2 to write the next consecutive word?
    Will it be the same for the I2CREAD?
    I tried several manner of writing and reading and it didn't help me...
    that's true. An eeprom store a byte in each address location ( well those i know and use). So if you want to store a word... it will need to adresses. That's not a bug
    Simon Brodeur Guest
    Also, will any previous value at the same address be overwrited?
    As long as you increment/decrement your address by 2 you shouldn't overwrite any previous/next data.
    Writing to the same adress ( let's say $06) will overwrite the previous value wich was @ $06 and $07
    Wink
    Hi, Simon
    I had the same problem with EEprom 16 bits storing ...
    a simple way is to trucate values into Value.lowbyte and value.highbyte
    for addressing, i.e use addresses for Highbytes as 2*n and for lowbytes as 2*n + 1 ...
    and when reading you do the same.
    there's no mix that way - just takes 2 I2CWRITE lines instead of 1 !!!
    as address is defined as a Word ... the count for me is 65536 locations at max ...so, it could explain overwriting some values !!! for 256k you will probably have to add some extra block addressing.
    in French .... would be easier !!! let's say this accelometer makes me think to something in the air ....
    Simon Brodeur Guest
    I resolved some problem in my code, but something trouble me about the FOR...Next loop. My code is :
    For address = 0 to last STEP 4
    I2CREAD SDA,SCL,cbit,address,[xsend.Highbyte]
    address = address + 1
    I2CREAD SDA,SCL,cbit,address,[xsend.Lowbyte]
    Next
    My value in my EEPROM are like this (numbers are EEPROM locations) :
    01 23 45 67 89
    |xx|yy|xx|yy|xx|...
    Normally, the output value of address should be : 0,4,8,12,16,...
    But will the '' address = address + 1 '' line affect this output, giving result like this : 0,5,10,15,20,... ????????
    This should be an easy question for you
    Simon Brodeur Guest
    I got it working...
    I just simply read by word instead of read by byte...
    Thanks you guys
  1. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  5. calculation problem
    Last Post: - 31st March 2006, 15:23
