PIC16F1503 Fixed Voltage Reference
Results 1 to 11 of 11
    Default Re: PIC16F1503 Fixed Voltage Reference
    it could be worded better. the hight-lighted word "reference" could be removed to better reflect reality
    The Fixed Voltage Reference (FVR) is a stable voltage
    reference, independent of VDD, with a nominal output
    level (VFVR) of 1.024V. The output of the FVR can be
    configured to supply a reference voltage to the
    following:
    • ADC input channel
    • Comparator positive input
    • Comparator negative input
    The FVR can be enabled by setting the FVREN bit of
    the FVRCON register
    Jan 2011
    Sydney, Australia
    the exact same wording is used in the PIC16F1829 datasheet yet that device DOES have the option to set the ADC Vref+ to the internal FVR module (ADPREF<1:0> = 11)
    Some consistency would be a good thing....
    Cheers
    Barry
    VK2XBP
    Come on guy, Microchip can't even decide what to call basic registers. Hay hoo.
    George
    OK
    I ran into this exact issue with this exact PIC! I swapped over to a PIC16F18323. I wanted to monitor battery voltage. If input voltage were to start dropping with ADC referencing Vdd, I may never see a dying battery until it was too late. Referencing ADC to 2.048 volts with a voltage divider on the input made it more precise. I think that's similar to what you are trying to do.
    Jan 2011
    Sydney, Australia
    That is EXACTLY what I am trying to do!
    I have looked at PIC16F1703, PIC16F1823 and the one you recommended, PIC16F18323 - all are pin compatible and have the ability to set the FVR as the reference voltage for the ADC.
    Cheers
    Barry
    VK2XBP
    if all you need to do is calculate vdd then
    connect adc to fvr and measure fvr count
    vdd = 1024*fvr_const/fvr_count
    fvr_const would be very close to 1.000 and could be determined using a calibrated power supply if required
    Jan 2011
    Sydney, Australia
    Thanks Richard.
    The PIC is being fed via a liner regulator so I am not that interested in reading Vdd.
    I want to read the battery voltage feeding this 5V linear reg. The battery also feeds a 6V buck regulator.
    I have the ADC pin fed via a voltage divider.
    All works well until the battery voltage drops sufficiently cause Vdd to droop, thus throwing off my ADC readings and battery status indicator LEDs.
    Given there are numerous pin compatible devices which allow the FVR module to be used as a reference voltage for the ADC, I believe my easiest path forward is to change devices.
    These are not expensive devices (~AUD$1.50 for single unit purchase) so making the change has no real drawbacks.
    Cheers
    Barry
    VK2XBP
  1. Replies: 8
    Last Post: - 21st March 2015, 18:21
  2. Replies: 1
    Last Post: - 18th February 2014, 03:39
  3. 16F886 and Voltage reference
    Last Post: - 25th August 2013, 19:15
  4. Fixed Voltage Reference
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2012, 12:27
  5. Replies: 7
    Last Post: - 22nd January 2012, 05:50
