PIC16F1503 Fixed Voltage Reference
Results 1 to 11 of 11
    Default Re: PIC16F1503 Fixed Voltage Reference
    a quick look at the data sheet leaves you with only two option for positive reference
    vdd or external vref
    Jan 2011
    Sydney, Australia
    Hi Richard,
    Yes, I see that now but contradictory to this diagram, the datasheet also states that the output of the FVR can be configured to supply a reference voltage to the ADC input channel:
    and this is supported in the FRVCON register (bits 1-0) regarding the relevant ADC FVR buffer gain:
    Which one is to be believed?
    Cheers
    Barry
    VK2XBP
    it could be worded better. the hight-lighted word "reference" could be removed to better reflect reality
    The Fixed Voltage Reference (FVR) is a stable voltage
    reference, independent of VDD, with a nominal output
    level (VFVR) of 1.024V. The output of the FVR can be
    following:
    • ADC input channel
    • Comparator positive input
    • Comparator negative input
    The FVR can be enabled by setting the FVREN bit of
    the FVRCON register
    Jan 2011
    Sydney, Australia
    the exact same wording is used in the PIC16F1829 datasheet yet that device DOES have the option to set the ADC Vref+ to the internal FVR module (ADPREF<1:0> = 11)
    Some consistency would be a good thing....
    Cheers
    Barry
    VK2XBP
    Come on guy, Microchip can't even decide what to call basic registers. Hay hoo.
    George
    OK
    I ran into this exact issue with this exact PIC! I swapped over to a PIC16F18323. I wanted to monitor battery voltage. If input voltage were to start dropping with ADC referencing Vdd, I may never see a dying battery until it was too late. Referencing ADC to 2.048 volts with a voltage divider on the input made it more precise. I think that's similar to what you are trying to do.
    Jan 2011
    Sydney, Australia
    That is EXACTLY what I am trying to do!
    I have looked at PIC16F1703, PIC16F1823 and the one you recommended, PIC16F18323 - all are pin compatible and have the ability to set the FVR as the reference voltage for the ADC.
    Cheers
    Barry
    VK2XBP
  1. Replies: 8
    Last Post: - 21st March 2015, 18:21
  2. Replies: 1
    Last Post: - 18th February 2014, 03:39
  3. 16F886 and Voltage reference
    Last Post: - 25th August 2013, 19:15
  4. Fixed Voltage Reference
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2012, 12:27
  5. Replies: 7
    Last Post: - 22nd January 2012, 05:50
