Chattering relay
Results 1 to 11 of 11
    Default Chattering relay
    Looking for ideas to eliminate chattering of my relays that are activated depending on the ADvalue that is read from the analog input.
    The Analog value is filtered through DT_Analog module (Analog oversampling to 12 bits).
    But on the decision point, relays are chattering on/off as the analog value is slow changing.
    gosub getADC
        'ADvalue=abs (ADvalue-818)
        if ADvalue < upper then
            relay.0=1
            relay.0=0
        if ADvalue < mid_upper then
            relay.1=1
            relay.1=0
        if ADvalue < mid then
            relay.2=1
            relay.2=0
        if ADvalue < mid_lower then
            relay.3=1
            relay.3=0
        if ADvalue < lower then
            relay.4=1
            relay.4=0
    Any ideas?
    Default Re: Chattering relay
    the obvious way is note when a relay state change occurs
    then inhibit any further state change until a determined period has elapsed
    Sep 2009
    Hysteresis, maybe?
    Thanks.
    I tried hysteresis but there are 4 decision points and things are getting messy.
    I set up Timer 1, counting seconds. The main loop runs fast but the relays are set (or reset) only after the defined time delay, now 10 sec.
    Seems OK.
    gosub getADC
            relay.0=1
            relay.0=0
            relay.1=1
            relay.1=0
            relay.2=1
            relay.2=0
            relay.3=1
            relay.3=0
            relay.4=1
            relay.4=0
    Any ideas?
    how about something like this for virtual hysteresis:
            if upperbufferflag=0 then 'add the buffer only once
                upper=upper+upperbuffer:upperbufferflag=1
            relay.0=1
            if upperbufferflag=1 then 'subtract the buffer
                upper=upper-upperbuffer:upperbufferflag=0
            relay.0=0
    (typical for each instance)
    picster
    Thanks picster.
    What I finally did is this:
     if ADvalue < upper-hyst then
                relay.0=1
            elseif ADvalue > upper+hyst then
                relay.0=0
    The user through menu, can set the hyst (hysteresis) window.
    Also the update of the relays is not done immediately but every xx seconds also user defined.
    Both these did the trick.
    VERY slick solution. Great for reference for cases where hysteresis is needed, thanks for sharing!
    Picster
    Thanks picster. It works very reliable, especially in my case where the value does not change too quickly.
    I see your software worked but you might need more capacitor filtering of the A/D voltage input, especially when operating relay
  1. Question on Relay?
    Last Post: - 29th May 2010, 16:02
  2. PIC to Relay
    By Kalind in forum Schematics
    Last Post: - 24th January 2009, 01:53
  3. Relay
    By menta in forum General
    Last Post: - 1st October 2008, 16:04
  4. SPST Relay
    By docwisdom in forum Off Topic
    Last Post: - 15th June 2006, 00:16
  5. drive relay?
    By serdar_ozcan in forum mel PIC BASIC Pro
    Last Post: - 26th November 2005, 11:01
