Digital Pot
Results 1 to 7 of 7
Thread: Digital Pot
    Scott's Avatar
    Scott Guest
    Default Digital Pot
    I am looking at building a test board that using a Digital potentiometer such as the Analog devices AD5160 or the Microchip MCP42XXX to simulate a 10k ohm thermistor via software.
    Can someone give me some pointers?
    Has anyone attempted anything like this?
    Any help would be great,
    Scott
    Digital pot is one option BUT there's probably cheaper way to do it depending on how the Thermistor is place in the circuit. Generating a coltage with PWM and a op-amp buffer could do the same job.
    BTW do you have a schematic of the Thermistor section you want to simulate?
    Scott's Avatar
    Scott Guest
    Voltage will be supplied by another I/O board. I want to vary the resistance to simulate the changing of the temperature with the digital potentiometer. Does this make sense? I would like to place the board that will be simulating the 10k ohm thermistor in the same location as the real 10k ohm thermistor.
    I am trying to simulate earlier captured data.
    I do not have a schematic for the sensor!
    Scott
    Sure it make sense no problem. Yes you can use Digital pot for that but you'll be limited to their own position/taps limitation.
    Good luck.
    Here's the code I wrote to control 5 digital pots daisy chained together.
    DEFINE  LOADER_USED 1   ' Bootloader is being used
    DEFINE  OSC 16          ' Set oscillator frequency, 4MHz (HS_PLL x4)
    DEFINE  HSER_BAUD 9600  ' Baud rate for serial output
    DEFINE  HSER_CLROERR 1  ' Automatically clear over-run errors
    DEFINE  HSER_RCSTA 90h	' Enable USART receive
    DEFINE  HSER_TXSTA 24h	' TXSTA=%00100100. TX enable, BRGH=1 for high-speed
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    ' Oscillator Switch Disable
    ' Oscillator Type HS PLL
    @ __CONFIG _CONFIG2L, _BOR_ON_2L & _PWRT_ON_2L & _BORV_45_2L
    ' Brown-Out Reset Enabled
    ' Power-Up Timer Enable
    ' Brown-Out Reset Voltage 4.5V
    @ __CONFIG _CONFIG2H, _WDT_ON_2H
    ' Watch Dog Timer Enable
    @ __CONFIG _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ' Stack Over/Underflow Reset Enable
    ' Low Voltage ICSP Programming Disabled
    ' Background Debugger Disabled
        ADCON1 = %0111              ' Set porta to digital mode
        si      var     porte.2
        sclk    var     porte.1
        cs      var     porte.0
        pot_value_0 var     byte
        pot_value_1 var     byte
        pot_value_2 var     byte
        pot_value_3 var     byte
        pot_value_4 var     byte
        cmd         var     byte
        position    var     byte
        low     sclk    ' Set clock pin low
        high    cs      ' Set chip select low
        clear
    start:
        gosub pot_5
        gosub pot_4
        gosub pot_3
        gosub pot_2
        gosub pot_1
        goto start
    pot_5:
        low cs
        cmd = %00010001 : position = pot_value_4 : gosub shout
        cmd = 0 : position = 0 : gosub shout
        high cs
    pot_4:
        low cs
        cmd = %00010010 : position = pot_value_3 : gosub shout
        high cs
    pot_3:
        low cs
        cmd = %00010001 : position = pot_value_2 : gosub shout
        high cs
    pot_2:
        low cs
        cmd = %00010010 : position = pot_value_1 : gosub shout
        high cs
    pot_1:
        low cs
        cmd = %00010001 : position = pot_value_0 : gosub shout
        high cs
    shout:
        shiftout si,sclk,1,[cmd]
        shiftout si,sclk,1,[position]
    Just set the pot_value_x to whatever you want between 0-255.
    Scott's Avatar
    Scott Guest
    Wow!
    Thanks for the code I'll give it a try this week and let you know.
    Scott
    If you need any help with them just give me a shout.
  1. Digital Pot
    Last Post: - 3rd January 2012, 08:54
  2. Controlling a MCP4162 Digital Pot
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 6th February 2011, 19:51
  3. Digital Pot Advice
    Last Post: - 22nd October 2007, 21:38
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. Serial control of a digital pot?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2006, 00:49
