One-Wire Timing Using PLL
Results 1 to 8 of 8
    Well I tried the caps thing and the same result. I then again tried the parasite power right on the board and it worked fine so that got me thinking about the 4.7k pull-up on the data line. I thought that maybe the resistance was a little too high so I tried a 2.2k and low and behold, it can to life. What I don't really understand though is why the difference when I switched between the 4 and 10 MHz crystals.
    Well all i can say, using the PLL the difference is 24MHZ. The problem would be the same with some I2C device at high SCL frequency. Some datasheet will suggest 1.8K for high frequency and 4.7K for lower frequency.
  1. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 03:30
  2. 18F4520 and internal osc & PLL
    By pwhitt in forum mel PIC BASIC Pro
    Last Post: - 15th September 2008, 07:38
  3. 16F628 and LMX2306 PLL loading.. help
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 18:03
  4. Pll?
    By atwoz in forum General
    Last Post: - 19th December 2007, 11:20
  5. RPM with wire and PIC
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 14th December 2004, 21:42
