Problems whith pulsin
Results 1 to 4 of 4
    you can probably use COUNT to do the job.
    Detecting 7.5Khz with +/- 10% => from 6.82 KHZ to 8.25 Khz
    so what about the following
    ' Pic 16f84 at xtal 4 Mhz. WDT off PTU off'
    ' Detecting 7.5Khz with +/- 10% => from 6.82 KHZ to 8.25 Khz
    FI VAR PORTA.3 'input freq
    SO VAR PORTB.0 'OUPUT LED
    W0 VAR WORD    'VARIABLE W0
    INIT:
        count fi,100,w0 ' Count pulses for 100ms
        IF (W0>682) AND  (w0<825) then PULSE
        GOTO INIT
    PULSE:
        HIGH SO
        PAUSE 500
        LOW SO
        PAUSE 500
        GOTO INIT
    melectro's Avatar
    melectro Guest
    Default problems whith pulsin
    Thanks mister_e ,I change the instruction to count and work good,but now the problem is that the pulse that receive is very short soupouse <20 ms (exactly the minimus time that close one ****ch ) this shut an 4064 to the reset an via RF send me the signal to receiver in the ouput I have the wave perfec.I soupouse that the time to take the measurement are big (100ms) in comparation whit the small pulse that shoot pulse:
    count F1,100,W0
    I change the value 100 to 75 50 and 25 but the program not work an change too the values that W0 .
    IF (W0<600) and (W0>850) then pulse
    but no work
    I think ,if I count in 100 ms and the pulse to shoot are 20 ms I need to ajust the time fine to make the measurement more precise,but...
    Any help
    Melectro
    there's probably many method. but did you tried with a sampling time of 10ms with a range of 68 to 82?
    Where the pulses cme from? did you monitor it to see if they're clean with the right amplitude?
    Before thinking of using internal counter or interupt, can you try the following and post your result?
    ' measuring the frequency period =>147uSec to 121uSec
    W0      VAR byte
    TLow    var byte
    THigh   var byte
    INIT:
        pulsin fi,0,Tlow
        pulsin fi,1,Thigh
        w0=tlow+thigh
        IF (W0<15) AND  (w0>12) then PULSE
        GOTO INIT
    PULSE:
        HIGH SO
        PAUSE 500
        LOW SO
        PAUSE 500
        GOTO INIT
    make sense to me ... after being more than 24 hours awake...
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 10:17
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  4. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 13:52
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 14:45
