VEML6040 I2C sensor problem
Results 1 to 3 of 3
    Feb 2018
    Default VEML6040 I2C sensor problem
    Hello,
    Wondering if anyone has used the Vishay VEML6040 color sensor with I2C interface. I am having trouble reading it and think it might be related to the fact that you need to send a command code byte followed by a read without a stop bit after the command code byte. Here is the format.
    StartBit-SlaveAddress-WriteBit-Ack-CommandByte-Ack-StartBit-SlaveAddress-ReadBit-Ack-DataByteL-Ack-DataByteH-Ack-StopBit
    Is this possible to do with the built in I2C commands?
    Default Re: VEML6040 I2C sensor problem
    that's what they are for
    Feb 2018
    Let me try asking it this way...
    Will the built in I2C commands allow for a device which needs a repeated start condition in order to read?
  1. Anyone used the TMP102 temperature sensor (I2C interface)
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 24th June 2011, 23:58
  2. TMP100 I2C sensor
    By ngeronikolos in forum mel PIC BASIC Pro
    Last Post: - 21st September 2010, 15:47
  3. Need help for reading I2C Sensor
    By Omalik in forum Serial
    Last Post: - 10th June 2008, 04:24
  4. more-than-8 bit temperature sensor I2C
    By picster in forum mel PIC BASIC Pro
    Last Post: - 13th March 2006, 20:29
  5. I2C sensor Quirk
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 27th May 2005, 03:32
