Safely getting out of an interrupt
Results 1 to 16 of 16
    Alabama,USA
    Default Safely getting out of an interrupt
    Working with DT interrupts(-14), Darrel stated many times to get out of the interrupt as soon as possible. I think this is because of the limited stack. So what exactly does it mean to get out of the interrupt? Of course INT_RETURN gets you out, but what if you don’t want to return to where you were interrupted? I would think that all that is needed is to clear the flag bit, am I wrong? Will this do the trick? Offhand I can’t think of anything else that DT may have done that must be dealt with.
    INT_Disable xxx_INT ;clear enable bit
    INT_CLEAR xxx_INT ;clear flag bit
    GOTO NewLocation
    Once you are at the new location you do a INT_Enable when ready for the next INT? I’m working with Hserin.
    Wayne
    Default Re: Safely getting out of an interrupt
    am I wrong?
    yes , totally
    interrupts are really a special type of gosub, one that can occur not from a set point in code space but one that occurs when an external stimulus occurs.
    secondly , a 14bit core chip has only one interrupt level only
    Alabama,USA
    Richard,
    Thanks for responding.
    So, your saying there is more to the interrupt than saving Status, w, saving address, enabling bits, setting or clearing flags? I want to receive an interrupt RX_INT and as soon as the program has jumped to the Label ( _ReciveData), I can stop the interrupt routine, take care of business, then go to somewhere in the program other than the program location of that interrupt. If I use INT_Disable and INT_CLEAR what is left hanging? What else needs to be taken care of? I don't care about the old w, I don't care about the old status, I don't care about the old address. Please explain what i'm missing.
    Wayne
    the problem is that it then becomes a once only event , the pic will never branch to another interrupt.
    Alabama,USA
    richard,
    OK, so after I’ve thought about this perhaps its not my program that would have a problem but DT’s interrupt. If it acts as a special gosub then there may be some return address and flags that have to be taken care of. Is that correct? If so, how do you get out of it without using INT_RETURN?
    it can't be done any other way except with a reset
    OK
    I believe you would have to POP the Stack, which is to remove the Saved Address the Interrupt was called from. Otherwise you'll eventually get Stack Overflow. If you only need that INT once after start-up, may not be an issue.
    Alabama,USA
    thanks for all the input. I've go to chew on this a while. perhaps DT_Handler macro may give some clues as to what would be required.
    Wayne
    so, on rcv-int.... save the character to mem or ram to work on in basic later, and raise some flag to be checked in basic that char is in system and leave int.... only takes few micro-seconds to bring chars into system. Can do a few machine code instructions to move character pointer, look for certain incoming character and/or reset character array in the int routine, again all few micro seconds depending on osc. Then always ready for next rcv.
    Aug 2011
    Perhaps the real question to ask is why do you feel you need to do that?
    Alabama,USA
    All I'm after is to transfer to a location other than where the INT occurred. I'm going to take a closer look at DT_INTs-14 and try to figure out if there are any system var that need to be dealt with. Other than that I think the only thing that is needed is to pop the stack and loose the address.
    dream on
    typical stack implementation from data sheet core14 non enhanced pic
    4.3.2 STACK
    The PIC16F627A/628A/648A family has an 8-level
    deep x 13-bit wide hardware stack (Figure 4-1). The
    stack space is not part of either program or data space
    and the Stack Pointer is not readable or writable. The
    PC is PUSHed onto the stack when a
    CALL instruction
    is executed or an interrupt causes a branch. The stack
    is POPed in the event of a
    RETURN, RETLW or a
    RETFIE
    instruction execution. PCLATH is not affected
    by a PUSH or POP operation.
    Note
    1: T
    here are no Status bits to indicate stack overflow or stack underflow conditions.2:There are no instructions/mnemonics called PUSH or POP. These are actions that occur from the execution of the
    CALL, RETURN, RETLW and RETFIE instructions, or the vectoring to an interrupt address.
    Dec 2010
    A safer approach is to simply have the interrupt set a flag and return. You main program can be a tight loop that checks flags. When to detects the flag, it GOSUBs to the new location.
  1. Replies: 0
    Last Post: - 27th August 2004, 07:20
