PIC12F683 pin GP3 as output
Results 1 to 15 of 15
    Default Re: PIC12F683 pin GP3 as output
    Hello,
    in PICAXE no need to use any config.
    In picbasic I use this:
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    But I also used this:
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _CP_OFF
    The weak pullup on GP3 is enabled only when MCLR is enabled.
    You may try also ANSEL to set it to
    DO
    ANSEL=0
    PAUSE 500
    ANSEL.3=1
    PAUSE 500
    LOOP
    This will enable and disable the weak pullup.
    DO
    ANSEL=0
    PAUSE 500
    ANSEL.3=1
    PAUSE 500
    LOOP
    tried, not working. ANSEL.3 is for pin GP4 not for GP3.
  1. Question on using MCLR pin for interupt. (PIC12F683)
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 7th February 2009, 03:15
  2. Turn on output pin
    Last Post: - 11th March 2007, 12:49
  3. Input / output using same pin
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:19
  4. using TOCK pin as output?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 8th November 2006, 18:15
  5. How to set analog pin to output 5V?
    By james in forum mel PIC BASIC Pro
    Last Post: - 8th July 2004, 08:24
