PC / PIC communications?
Results 1 to 2 of 2
    achilles03's Avatar
    achilles03 Guest
    Default PC / PIC communications?
    I'm relatively new to PB, but I was wondering what's the easiest way to communicate between a PIC and a PC? Serial? RS232? I guess what I really need to know is:
    1. what cable do I need
    2. what software can I use to interface the PIC
    3. what additional software configuration I need to do
    My main goal is to be able to get the PIC to output data that is stored on a 32kbyte eeprom, which was written by the PIC initially.
    Thanks for any advice!
    Dec 2003
    Wichita KS
    Hello Achillies,
    No cable necessary... 3 wires...going to your RS232.
    I used Procomm
    The pic I used T2400 for the transmittion rate, so that other parts were not necessary.
    Additional Software? I can only assume you mean software for your PC. Most any software will work, you may have to adjust the baud rate, or invert your signal from your PIC chip. (or use a MAX chip).
    Melanie put a beautiful program on this board, that does probably what you want... I Did a search on it.
    http://www.picbasic.co.uk/forum/showthread.php?t=573
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. Replies: 24
    Last Post: - 2nd October 2017, 12:35
  2. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 23:04
  3. Replies: 67
    Last Post: - 8th December 2009, 03:27
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  5. Replies: 11
    Last Post: - 12th July 2008, 03:36
