I2C fast to slow at runtime
Results 1 to 7 of 7
    Mar 2005
    Cocoa, Florida
    Default I2C fast to slow at runtime
    This project requires a 100k device and a 400k device on the same bus.
    The I2C slow command appears to be compile only.
    Is there a way to change fast to slow and back again at runtime?
    Thanks.
    Sep 2009
    Default Re: I2C fast to slow at runtime
    No. But as far as I know all 400K devices work on 100K.
    Mar 2005
    Cocoa, Florida
    Yes, it works fine. At the moment we have a 900 us read (Honeywell pressure sensor), but at 400k it's about 225 us, and saving the extra time would be useful.
    If you need the speed, then what devices are running at 100K?
    EN82fn
    or use the mssp module if your chip has one
    http://support.melabs.com/forum/picb...c-hardware-i2c
    Mar 2005
    Cocoa, Florida
    Microchip TC74.
    We used this for the TO-220 packaging - it is screwed to a motor where it is difficult to put a PCB.
    Mar 2005
    Cocoa, Florida
    Thanks, I'll look into that.
  1. Replies: 2
    Last Post: - 12th April 2017, 14:38
  2. Is it possible to have determine array size in runtime
    By MajidF in forum mel PIC BASIC Pro
    Last Post: - 21st March 2016, 16:52
  3. Changing CONFIG @ runtime possible ???
    By Acetronics2 in forum PBP3
    Last Post: - 8th April 2014, 19:47
  4. Configure Debug @ runtime?
    By dhouston in forum Serial
    Last Post: - 11th November 2011, 21:04
  5. Redefinition of CON bmode during runtime
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 16th February 2008, 22:57
