High Voltage, MCU controled 300Volt power supply
Results 1 to 10 of 10
    Sep 2009
    Default Re: High Voltage, MCU controled 300Volt power supply
    You didn't mention nothing about ripple, resolution, off line or main referenced, earth referenced, isolated...
    I would go with offline full bridge phase shifted forward smps with linear output stage.
    http://www.ti.com/lit/ug/tidu248/tidu248.pdf
    Thanks for replying.
    You are right about that specs. Not very critical and too many to load the initial thread.
    Your post shows a step down (12V/50A) converter. My need is to have an output of 10-300 Volts with whatever input. Either direct from mains or from other source, lower dc maybe.
    The design should provide control over the output voltage and the load current (in the range 0-400mA).
    That makes for a 120 Watt to the load power supply.
    With linear approach the losses are too high in components such as the Pass transistor (10V output at 0,4A drops 130 Watts) and other passive components too, like bias resistor and control circuit.
    A linear example is shown in this page: http://sound.whsites.net/project151.htm
    A switching of such a wide control (10-300 volt output) is not easy one.
    Sep 2009
    That is first example that I found to get theory of operation for phase shifted forward smps. You calculate your transformer for maximum voltage that you need on output, with lowest voltage on input.
    If your phase is 180deg out of phase, you will have full voltage on output.
    If your signals are just little bit off phase you will have very short impulses on transformer, and output filter(this is basically buck converter), will average that short impulse to low voltage. With relatively high ripple, so that is reason I suggested linear output stage. Output voltage of SMPS just need to be few volts higher than output voltage. So linear post regulator will have relatively easy job(not much disipation).
    Any other architecture, as far as I know, cant generate very short impulses without causing major loses in mosfets.
    For example if you calculate your flyback to give 300V with 80% duty then you need 0,5% of PWM for 10V on output(approximately). If your flyback work around 40KHz, your PWM period is 25uS. Your PWM pulse width for lowest voltage will be 0,125uS.
    I wouldn't even try to generate that...
    But if you have enough resolution for phase control, you can relatively easy generate that pulse on transformer. You have relatively small output current, so you can omit synchronous rectifying.
    I wonder what happened to my answer... Just disappeared!
    Thank you for the explanation. Looks very interesting in theory and I hope this can be realized for the needs of this power supply.
    At 10V I thing it is 2,67% but in any case it is too low. Difficult to obtain such short pulses...
    Sep 2009
    You are right, I just put low percent from top of my head. Anyway is still sub 1uS.
    Just came to my mind, If you have linear output stage, lowest SMPS voltage could be much higher, eg 40V. In that case you will have only 16W of dissipation in linear stage(in worst case).
    40-300V is much easier design.
    For linear output stage Ill suggest you this design:
    https://www.eevblog.com/forum/chat/d...-supply-build/
    If you carefully read schematic you will notice that all circuit is floating around output voltage.
    Also this might help:
    Electrophoresis Power Supply Teardown
    Wow, exactly what I needed! Thanks a lot!
  1. Replies: 8
    Last Post: - 21st March 2015, 17:21
  2. Multi Voltage DC Power Supply
    By PJALM in forum General
    Last Post: - 22nd July 2012, 02:53
  3. Giving power to MCU upon button press - Good Idea?
    Last Post: - 21st July 2009, 07:34
  4. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 11:50
  5. Replies: 4
    Last Post: - 20th September 2005, 15:27
