8870/dtmf + Pic?
Results 1 to 3 of 3
    PIC_hobbyist's Avatar
    PIC_hobbyist Guest
    Default 8870/dtmf + Pic?
    Does anyone know how to read the DTMF signals into a PIC 16F84? And how to connect the output binary lines to the input of the PIC?
    Basically I want to be able to connect a phone to a 8870 DTMF decoder and have it so that if I enter a certain code (ex...*123#) on the telephone than the 8870 will decode it, and spit out the binary values to the PIC. Once the PIC receives the values I can have it scan the inputs, if the code is correct (*123#) than I can make the outputs do somehing...
    Any assistance or example would be greatly appreciated!
    picstudent's Avatar
    picstudent Guest
    Default help
    i think i can help you, but bye the other side i need the input circuitry (microphone adaptation), 'cause i was worki' this on proteus (good sims).
    I'll sent you my proteus files soon.
    best regards
    mail me!!
    Mar 2013
    Default Re: help
    hi, i need help for identical problem.
    i need use same code, example *123 to active any oupt in pic 16f628a witch 8870 decoder.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
    Last Post: - 12th March 2005, 00:14
