PIC12F683 pin GP3 as output
Results 1 to 15 of 15
    Default PIC12F683 pin GP3 as output
    Hello folks,
    before I tried play with picbasic I worked with PICAXE. I have done few projects with PICAXE 08M2 which is a rebranded PIC12F683 with bootloader.
    In PICAXE is one simple cheat which allows to use the pin3 (MCLRE) as output. Pin3 drives an NPN transistor via manipulating weak pullup resistor. In attachment find the schematis which I use wery often. It works fine all the time.
    For example here is a simple led blinking code in PICAXE looks like:
    #picaxe 08m2
    do
    pullup $08    ;pullup on GPIO.3 LED ON
    disable          ;disable pullups LED OFF
    loop
    Now the question is how do they made it? I try similar on PIC12F683 in picbasic but no success.
    Try to led blinking code in picbasic like:
    ;PIC12F683
    TRISIO=0
    ANSEL=0
    OPTION_REG.7=1   ;enable WPU
    strt:
    wpu=%00001000      ;enable WPU on GPIO.3
    wpu=%00000000      ;disable WPU on GPIO.3
    goto strt
    OK, I now this is not work. I also now the GPIO.3 WPU is activatable only via
    MCLRE, the GP3 pull-up is enabled when MCLRE is set to"1" in the configuration word register, and disabled when MCLRE is set to"0".
    How It works in PICAXE, thats the question. Does anyone have an idea?
    Louis
    Default Re: PIC12F683 pin GP3 as output
    can you post also the fuse configuration?
    Hello,
    in PICAXE no need to use any config.
    In picbasic I use this:
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    But I also used this:
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _CP_OFF
    The weak pullup on GP3 is enabled only when MCLR is enabled.
    You may try also ANSEL to set it to
    DO
    ANSEL=0
    PAUSE 500
    ANSEL.3=1
    PAUSE 500
    LOOP
    This will enable and disable the weak pullup.
    DO
    ANSEL=0
    PAUSE 500
    ANSEL.3=1
    PAUSE 500
    LOOP
    tried, not working. ANSEL.3 is for pin GP4 not for GP3.
    Oct 2011
    Try setting GP3 to input as setting to output turns off weak pull-ups
    GP3 is setupable only as input.
    OK, then this would only work if one could change the MCLR bit in config word, address 2007h.
    But this can only be accessed in Programming the chip...
    Interesting one!
    GP.3 is only configurable as an added input pin when nor being used as the RESET pin. NO output configuration is possible.
    EN82fn
    yes, if I configure the MCLR bit in config word to "1" then the LED is ON because the transistor is open via internal pull-up. If I configute the MCLR bit to "0" then internal pull-up is disabled and the transistor is closed because the 1M resistor is pull the base to ground.
    That's work, but how to do that in program I don't know. However, it must work somehow, because in PICAXE environment it works.
    how sure are you that a picaxe 8m2 is a 12f683
    this makes me doubtful a 12f683 pegs out at 20mhz
  1. Question on using MCLR pin for interupt. (PIC12F683)
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 7th February 2009, 03:15
  2. Turn on output pin
    Last Post: - 11th March 2007, 12:49
  3. Input / output using same pin
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:19
  4. using TOCK pin as output?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 8th November 2006, 18:15
  5. How to set analog pin to output 5V?
    By james in forum mel PIC BASIC Pro
    Last Post: - 8th July 2004, 08:24
