Decoding serial data bytes and nibbles.
Results 1 to 7 of 7
    Default Decoding serial data bytes and nibbles.
    I have a hex serial 15 byte data stream in a byte array.
    ED,1E,D2,EF,2E,D3,ED,2E,D2,EF,2E,D3,ED,1E,D2,
    It needs to be chopped up into 10 x 12 bit data blocks as below.
    ED1,ED2,EF2,ED3,ED1,ED2,EF2,ED3,ED1,ED2
    How can i do that efficiently so I end up with each 12 bit block in a word array variable. eg
    DataWord[0] = ED1
    DataWord[1] = ED2
    etc etc
    Shifting came to mind but the logic scrambled my brain. Thanks for ideas
    Default Re: Decoding serial data bytes and nibbles.
    '* Name : UNTITLED.BAS *
    '* Author : David Purola *
    '* Notice : Copyright (c) 2018 Tronex Products *
    '* : All Rights Reserved *
    '* Date : 1/17/2018 *
    '* Version : 1.0 *
    '* Notes : *
    indata var byte[15] 'assuming byte 14 is most significant
    dataword var word[10] 'assuming word 9 is most significant
    outpointer var byte
    outpointer = 0
    while outpointer < 10
    select case outpointer
    case 9
    dataword(outpointer) = (indata(14) << 4) + (indata(13) & $f0)
    case 8
    dataword(outpointer) = ((indata(13) & $0f) << 8) + indata(12)
    case 7
    dataword(outpointer) = (indata(11) << 4) + (indata(10) & $f0)
    case 6
    dataword(outpointer) = ((indata(10) & $0f) << 8) + indata(9)
    case 5
    dataword(outpointer) = (indata(8) << 4) + (indata(7) & $f0)
    case 4
    dataword(outpointer) = ((indata(7) & $0f) << 8) + indata(6)
    case 3
    dataword(outpointer) = (indata(5) << 4) + (indata(4) & $f0)
    case 2
    dataword(outpointer) = ((indata(4) & $0f) << 8) + indata(3)
    case 1
    dataword(outpointer) = (indata(2) << 4) + (indata(1) & $f0)
    case 0
    dataword(outpointer) = ((indata(1) & $0f) << 8) + indata(0)
    end select
    outpointer = outpointer + 1
    wend
    EN82fn
    'another way....
    outpointer var byte
    inpointer var byte
    outpointer = 0
    inpointer = 0
    while inpointer < 12
    dataword.0((outpointer * 12) + inpointer) = indata.0((outpointer * 12) + inpointer)
    inpointer = inpointer + 1
    wend
    wend
    EN82fn
    neither of daves options works for me, I might be imagining the input differently
    would need 30 bytes and could be parsed using serin2 ...[hex3 dw[0],hex3 dw[1] .......
    I assume a input constructed like this,
    ie 15 binary values in this order ,
    arraywrite inbuff ,[$ED,$1E,$D2,$EF,$2E,$D3,$ED,$2E,$D2,$EF,$2E,$D3,$E D,$1E,$D2]
    this does work
      Pause 500       ' LCD initialize time
        lcdout $FE,1
        inbuff var byte[15]
        d var byte
        INPOINTER VAR BYTE
        outpointer var byte
        arraywrite inbuff ,[$ED,$1E,$D2,$EF,$2E,$D3,$ED,$2E,$D2,$EF,$2E,$D3,$ED,$1E,$D2]
        for d=0 to 4
        dataword[d*2]=inbuff[d*3]*16+inbuff[d*3+1]>>4
        dataword[d*2+1]=inbuff[d*3+2]+(inbuff[d*3+1]&$f)*256
        next
        for d=0 to 4
        IF D=4 THEN
        lcdout $FE,$80+d*4,hex3 dataword[d*2]
        lcdout $FE,$c0+d*4,hex3 dataword[d*2+1]
        lcdout $FE,$80+d*4,hex3 dataword[d*2],","
        lcdout $FE,$c0+d*4,hex3 dataword[d*2+1],","
        next
    daves idea compiles to be 200 words shorter . I like that
    but I still can't get it going
    to make I work
    the input array needs its bit order endianness reversed then the result needs the same treatment
    which defeats any gain
        for d=0 to 14
        inbuff[d]= inbuff[d] rev 8
        next
     outpointer = 0
     inpointer = outpointer*12
     d=0
     while d<12
     dataword.0((outpointer * 16) + d) = inbuff.0(d + inpointer)
     d=d+1
     wend
     dataword[outpointer]=dataword[outpointer] rev 12
     outpointer= outpointer + 1
     wend
    Thanks to all your help.
    I ended up using this bit but it's still boggling my mind a bit as to how it actually works.
       for d=0 to 4
        next
  1. I need to play with Nibbles, am i on the right track?
    By OldMarty in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 14:32
  2. Replies: 7
    Last Post: - 11th September 2010, 01:32
  3. incorrect requested number of data bytes recieved
    By doxdlite in forum mel PIC BASIC
    Last Post: - 17th April 2010, 23:47
  4. Word to nibbles
    By Gauge Guy in forum mel PIC BASIC Pro
    Last Post: - 11th September 2005, 05:08
  5. Serial Data Recorder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 13:45
