I am using PICBasic Pro in my example (this is a MeLabs compiler site after all!). That example WILL compile with the command line...
pbp -p16F84A Filename
All I did was alias PortB.0 to LED, and use LED thereafter... applying this to your example...
@ DEVICE pic16F84A, XT_OSC
@ DEVICE pic16F84A, WDT_ON
@ DEVICE pic16F84A, PWRT_ON
LED var PortB.0
AntiLED var PortB.1
TRISA=%00000000
TRISB=%00000000
Loop:
High LED
Low AntiLED
Pause 500
Low LED
High AntiLED
Pause 500
Goto Loop
of course you can always simplify the whole (original) loop...
Loop:
Toggle LED
Pause 500
Goto Loop
Aliasing you will find in your PBP manual. TRISA/TRISB you will find in the PICs Datasheet, and @ DEVICE you will find here...
