can someone help me check?
Results 1 to 18 of 18
    ARGH forget me, i didn't notice it was a ServoMotor. So the i/o current is not a problem now.
    While i don't see the same thing as you about the only one pin connection... it is connected on 15 and 16.
    BTW, do something. Remove both capacitor, crystal and their jumpers, and sit the crystal directly on pin 15 and 16. It will work without the cap... on bread board only.
    Next thing, did you set the osc mode to HS in your programmer software???
    Sep 2005
    Malaysia
    i am using epic programmer to program the chip. are you familiar with that? umm if not explain to me "osc mode to HS" so i can find it and change it...
    found it... but what is HS mode?
    -·=»‡«=·- saturnX -·=»‡«=·-
    Sep 2005
    Malaysia
    the good news is that the diode is not heating up.. the bad news is that the "servo motor" doesn't move until i break the diode connection and reconnect it back. even so its a small little jerk then nothing else.
    no i'm not familiar with EPIC. BUT place the following line on the top of your code. It will set the HS mode for you.
    @ __config _HS_OSC & _WDT_OFF & _PWRTE_ON
    more info on the following link. Pay attention on #1 and #5
    i'm over for tonight.. good night and good luck!
    Sep 2005
    Malaysia
    thanks for the help steve... guess i'm on my own for now. only 4 more hours to my presentation of this project. i am going to die! lolz!
    Italy
    Quote Originally Posted by saturnX
    I am so sorry to hear that!
    After all this hard work in the previous three days you must be exhausted!
    (Three threads in three days).
    Stay home, don't go to school.
    Luciano
    Sep 2005
    Malaysia
    Smile
    hi Luciano, i guess there is so only so much one person can do even with the help of the best. i just never understood why it didn't want to work. thanks for dropping by and the support. anything you can help me wif i welcome if with open arms
  1. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 18:11
  2. HARDWARE I2C SAMPLE CODE question
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 08:25
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
  5. Even Parity Check, How?
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 09:21
