I am using PICBasic Pro in my example (this is a MeLabs compiler site after all!). That example WILL compile with the command line...
pbp -p16F84A Filename
All I did was alias PortB.0 to LED, and use LED thereafter... applying this to your example...
of course you can always simplify the whole (original) loop...Code:@ DEVICE pic16F84A, XT_OSC @ DEVICE pic16F84A, WDT_ON @ DEVICE pic16F84A, PWRT_ON LED var PortB.0 AntiLED var PortB.1 TRISA=%00000000 TRISB=%00000000 Loop: High LED Low AntiLED Pause 500 Low LED High AntiLED Pause 500 Goto Loop
Aliasing you will find in your PBP manual. TRISA/TRISB you will find in the PICs Datasheet, and @ DEVICE you will find here...Code:Loop: Toggle LED Pause 500 Goto Loop
