can someone help me check?
Results 1 to 18 of 18
Threaded View
  1. #2
    The use of a diode to reduce the voltage is not the best solution if the target circuit don't need much current. In this case, the voltage drop on the diode will be less than what you wish.
    SO, your PIC is probably dead now and short. This is why your DIODE comes HOT.
    You should double check your crystal connection also.
    What is between the PIC and the Motor?
  1. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 19:11
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 09:25
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. Even Parity Check, How?
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 10:21
