Serial data transmission period
Results 1 to 11 of 11
    Oct 2009
    Default Re: Serial data transmission period
    I've used the second example with the case statement, and that appears to be working as expected
    Can you comment the code so that I can understand why it works
    Malc
    Jan 2006
    Istanbul
    Quote Originally Posted by Scampy View Post
    Malc
    CASE 0,5 will work on minutes 0,5,10,15,20,25,30,35,40,45,50,55 as the DIG 0 is always either 0 or 5.
    CASE 1,6 will work on minutes 1,6,11,16,21,26,31,36,41,46,51,56 as the DIG 0 is always either 1 or 6. And this gives you "1 minute pass" after your HSEROUT condition is executed.
    If you want to speed up the frequency of sending data, then change 0,5 to say 0,2,4,6,8 and 1,6 to 1,3,5,7,9. This way you can send data in every 2 minutes.
    If you want to slow down the frequency change 0,5 to 0 only and 1,6 to 1 only. This way you can send data in every 10 minutes.
    Hope this helps.
    Oct 2009
    Thanks for the explanation. I've copied and pasted it as notes in the code for use in later projects
  1. serial in data needs nib
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 4th June 2011, 13:20
  2. Transmission!
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 05:39
  3. serial data to LCD
    By cunninghamjohn in forum mel PIC BASIC Pro
    Last Post: - 25th November 2008, 16:50
  4. Replies: 7
    Last Post: - 6th February 2008, 06:38
  5. Multiplex serial data
    Last Post: - 19th May 2004, 01:28
