Serial data transmission period
Results 1 to 11 of 11
    Oct 2009
    Default Re: Serial data transmission period
    Quote Originally Posted by sayzer View Post
    This is one good way
    It seems that when this condition gets true, then it will send data for the duration of whole 1 minute.
    If you also add "Second" to this condition, it will also send the data for the duration of "1" whole Second.
    So a better way is to insert a flag into it.
    Uhmmmm.. still not working using the example you gave
    SendFlag var byte
    Sendflag =1
        OWOUT TEMPIN,1,[$CC,$44]
        OWOUT TEMPIN,1,[$CC,$BE]
        OWIN TEMPIN,0,[TempT.LowByte,TEMPT.HighByte]
        TempC = (TempT*/1600)
        LCDout $FE,$80,"Temp ",DEC (TempC/100),".",#TempC dig 1,"C"
        tempc=tempc/10
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]  ; read DS1307 chip
    LCDOut $FE,$c0+11,hex2 RTCHour,":",hex2 RTCMin
    LCDOut $FE,$c0, dec sendflag
    timeH=(RTCHour>>4)                                                       'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)
    If (TimeM//5) = 0 and SendFlag = 0 then
      Hserout [hex2 RTCHour,":",hex2 RTCMin," ",DEC(TempC/10),".",#TempC dig 1,13,10]
      SendFlag = 1
      If (TimeM//6) = 0 then SendFlag = 0
    'pause 1000
    At 8:00 for example (the programmed initial time on startup), the code would send data to the serial port as a constant stream every loop of the program rather than a single entry. I added a pause statement (commented out in the code above) so I could see what was happening, and the flag kept changing from 0 to 1 and back each loop of the code. When the time changed to 8:01 the value of the flag remained static at 1, and the data stream stopped, having sent 41088 bytes through the serial port.
    At 8:05 the flag remained at 1 and no data was sent. At 8:06 the flag changed to a value of 0 but again no data was sent, presumably as the condition to do so hasn't been met as whilst the flag is now zero, TimeM doesn't equal the 5 minute value ?
    The flag value remained at 0 until 8:10 when a single entry was sent to the serial port. The flag then changed to 1 remained at 1 as the time changed to 8:11 until 8:12 when it changed to 0 and remained at zero
    At 8:15 a single entry was sent to the port, the flag was set to 1 and remained at 1 until 8:18 when the flag value changed to 0
    The flag value remained at 0 until 8:20 when a single entry was sent to the serial port. The flag then changed to 1 remained at 1 until 8:24 when it changed to 0 and remained at zero
    At 8:25 a single entry was sent to the port, the flag was set to 1 and remained at 1
    At 8:30 the code sent data to the serial port as a constant stream every loop of the program rather than a single entry, with the LCD displaying a blur as the value alternated between 0 and 1. At 8:31 the data stream stopped and the flag was set to 0,
    So it seems to be following a pattern. Hope this feedback helps debug the code... it's beyond me !!
    edit:
    At 9:00 the code sent data to the serial port as a constant stream every loop of the program
    Jan 2006
    Istanbul
    It is my bad.
    (TimeM//6) may take another 2,3,4,5 minutes depending on the minute value
    You may want use "Second". Example;
    SendFlag var bit
    Begin:
    Sendflag = 0
    If (TimeM//5) = 0 then
      if RTCsec = 0 and SendFlag = 0 then
         sendflag = 1
         If RTCsec > 0 then SendFlag = 0
    or another way could be to use DIG ;
    SendFlag var bit
    Begin:
    Sendflag = 0
    SELECT CASE TimeM DIG 0
      Case 0,5    ' Every 5 minutes.
         if SendFlag = 0 then
            sendflag = 1
      case 1,6    ' Reset flag 1 minute later.
        SendFlag = 0
    END SELECT
    This one looks cleaner for my eyes.
    Oct 2009
    I've used the second example with the case statement, and that appears to be working as expected
    Can you comment the code so that I can understand why it works
    Malc
    Jan 2006
    Istanbul
    Quote Originally Posted by Scampy View Post
    Malc
    CASE 0,5 will work on minutes 0,5,10,15,20,25,30,35,40,45,50,55 as the DIG 0 is always either 0 or 5.
    CASE 1,6 will work on minutes 1,6,11,16,21,26,31,36,41,46,51,56 as the DIG 0 is always either 1 or 6. And this gives you "1 minute pass" after your HSEROUT condition is executed.
    If you want to speed up the frequency of sending data, then change 0,5 to say 0,2,4,6,8 and 1,6 to 1,3,5,7,9. This way you can send data in every 2 minutes.
    If you want to slow down the frequency change 0,5 to 0 only and 1,6 to 1 only. This way you can send data in every 10 minutes.
    Hope this helps.
    Oct 2009
    Thanks for the explanation. I've copied and pasted it as notes in the code for use in later projects
  1. serial in data needs nib
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 4th June 2011, 13:20
  2. Transmission!
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 05:39
  3. serial data to LCD
    By cunninghamjohn in forum mel PIC BASIC Pro
    Last Post: - 25th November 2008, 16:50
  4. Replies: 7
    Last Post: - 6th February 2008, 06:38
  5. Multiplex serial data
    Last Post: - 19th May 2004, 01:28
