Serial data transmission period
Results 1 to 11 of 11
    Oct 2009
    Default Serial data transmission period
    Guys,
    Need some advice for a bit of crude dirty code to send the time and temperature out via serial port.
        OWOUT TEMPIN,1,[$CC,$44]
        OWOUT TEMPIN,1,[$CC,$BE]
        OWIN TEMPIN,0,[TempT.LowByte,TEMPT.HighByte]
        TempC = (TempT*/1600)
        LCDout $FE,$80,"Temp ",DEC (TempC/100),".",#TempC dig 1,"C"
        tempc=tempc/10
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]  ; read DS1307 chip
    LCDOut $FE,$c0+11,hex2 RTCHour,":",hex2 RTCMin
    timeH=(RTCHour>>4)                                                       'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)
    Hserout [dec TimeH,":",dec TimeM," ",DEC(TempC/10),".",#TempC dig 1,13,10]
    Pause 5000
    This works fine, although I would rather data is sent once every 5 minutes. I did try and do a time match so that if minutes = 5 and seconds =0 it would send, but the program loops so fast that I still got multiple results.
    So I'm just after a quick and simple bit of code to allow me to record the temperature and time stamp every 5 minutes
    TIA
    Malc
    Default Re: Serial data transmission period
    Since your code executes about once every 5 seconds
    LoopCount VAR BYTE
    LoopCount = 0
    ' Rest of code goes here
    LoopCount = LoopCount + 1
    If LoopCount = 59 THEN   ' 60 times 5 seconds = 300 seconds = 5 minutes.
      LoopCount = 0
    Oct 2009
    Cheers Henrik,
    That works fine. But, is there a way of getting rid of the pause 5000 as that is obviously slowing down the sampling of the temperatures. I'm running the PIC with an OSC value of 40 with a 10 mhz crystal
    TIA
    Malc
    Edit, ignore me, I reduced the pause wait and increased the loopcount value - now have a more workable solution
    since you have a rtc and convert time to binary
    why not
    If (TimeM//5)==0 then
    Jan 2006
    Istanbul
    why not
    This is one good way
    It seems that when this condition gets true, then it will send data for the duration of whole 1 minute.
    If you also add "Second" to this condition, it will also send the data for the duration of "1" whole Second.
    So a better way is to insert a flag into it.
    For example;
    If (TimeM//5) = 0 and SendFlag = 0 then
      SendFlag = 1
      If (TimeM//6) = 0 then SendFlag = 0
    Oct 2009
    Thanks for the additional suggestions guys. I'll give them a try as well. Anything that removes the pause option from the code is good.
    Oct 2009
    Quote Originally Posted by sayzer View Post
    Uhmmmm.. still not working using the example you gave
    SendFlag var byte
    Sendflag =1
        tempc=tempc/10
    LCDOut $FE,$c0, dec sendflag
    timeM=(RTCMin>>4)
      Hserout [hex2 RTCHour,":",hex2 RTCMin," ",DEC(TempC/10),".",#TempC dig 1,13,10]
      SendFlag = 1
    'pause 1000
    At 8:00 for example (the programmed initial time on startup), the code would send data to the serial port as a constant stream every loop of the program rather than a single entry. I added a pause statement (commented out in the code above) so I could see what was happening, and the flag kept changing from 0 to 1 and back each loop of the code. When the time changed to 8:01 the value of the flag remained static at 1, and the data stream stopped, having sent 41088 bytes through the serial port.
    At 8:05 the flag remained at 1 and no data was sent. At 8:06 the flag changed to a value of 0 but again no data was sent, presumably as the condition to do so hasn't been met as whilst the flag is now zero, TimeM doesn't equal the 5 minute value ?
    The flag value remained at 0 until 8:10 when a single entry was sent to the serial port. The flag then changed to 1 remained at 1 as the time changed to 8:11 until 8:12 when it changed to 0 and remained at zero
    At 8:15 a single entry was sent to the port, the flag was set to 1 and remained at 1 until 8:18 when the flag value changed to 0
    The flag value remained at 0 until 8:20 when a single entry was sent to the serial port. The flag then changed to 1 remained at 1 until 8:24 when it changed to 0 and remained at zero
    At 8:25 a single entry was sent to the port, the flag was set to 1 and remained at 1
    At 8:30 the code sent data to the serial port as a constant stream every loop of the program rather than a single entry, with the LCD displaying a blur as the value alternated between 0 and 1. At 8:31 the data stream stopped and the flag was set to 0,
    So it seems to be following a pattern. Hope this feedback helps debug the code... it's beyond me !!
    edit:
    At 9:00 the code sent data to the serial port as a constant stream every loop of the program
  1. serial in data needs nib
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 4th June 2011, 12:20
  2. Transmission!
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 04:39
  3. serial data to LCD
    By cunninghamjohn in forum mel PIC BASIC Pro
    Last Post: - 25th November 2008, 15:50
  4. Replies: 7
    Last Post: - 6th February 2008, 05:38
  5. Multiplex serial data
    Last Post: - 19th May 2004, 00:28
