I made a model, using mono-color LED, and I2C port expanders. Worked extremely well.
I then made a model using RGB LEDs, again with port expanders and wired in a matrix so I could turn on just the red, just the green, blue, or any other combination. Of 16 LEDS I could light up just one, in any color. Great. I'm on a roll.
I made a small "test bench" using SSRs and 110V incandescent bulbs, using the SSRs in a matrix (column and row). There was some leakage through bulbs that were not supposed to be on (not triggered by an SSR) but for the most part it was manageable. So I scaled it up to the proper size: 48 incandescent bulbs in RGB colors (16 of each) and fed by 16 SSRs. For the color I had 3 SSRs feeding a "color bus". Didn't work. So much leakage through the bulbs (they aren't like LEDs, diodes and one way current) that when I tried to light ONE bulb, I get all three colors active. This even though I might only activate the Red color bus for example. I'm hooped. Not sure what to do now.
