16F88 and external Oscillator
Results 1 to 8 of 8
    Jan 2008
    Selm, Germany
    Default Re: 16F88 and external Oscillator
    Hello all around!
    I tried to put a EAGLE schematic attachment into this and I got the answer "Invalid file". How do I convert an Eagle document? I have to save PBP docs into txt format to post them. Is there anything like for EAGLE ?
    regards
    Mugel
    Aug 2011
    In EC mode the clock out on RA6 is FOSC/4, so with 20MHz on CLKI, CLKO will be 5MHz
    To post the schematic, either make a screen dump and post the image or print/export to .pdf and post that.
    I was going to say exactly what tumbleweed just did so now I won't, but I'll say this:
    Is it an actual oscillator (not a crystal or resonator) then you should be able to drive both PICs directly from the output of the oscillator but check the datasheet for the oscillator, I believe you can use either HS or EC mode for this.
    Jan 2008
    Selm, Germany
    Hello Henrik,
    Iīll try to get the image. No didnīt work, had 8MB Picture max is 1 MB.
    Jan 2008
    Selm, Germany
    Old Farts and Computers,
    here we go...Name:  18F1320+16F88.bmp
    OK, so it is a proper oscillator.
    Then just drive both PICs directly from it it. The way you have it now the second PIC will run at 1/4 the speed of the first one.
    Use .png instead of .bmp for images like this, much better!
    Jan 2008
    Selm, Germany
    Made several mistakes, killed one 18F1320 donīt know how , destroyed my PICKIT operating system, had to desolder and solder one 18F1320, BIG Mistake in the schematic: I had to use the lower 4 bits of PORTA and these begin at PORTA0 not PORTA1 . Put a resistor between 74HC14 and RB1 otherwise the PIC may be grilled.
    Changed config:
    CONFIG OSC = HS ;Clock out on RA6 :1/1 CLKI
    now the second PIC gets the same frequency out of the first PIC. Checked it with a scope.
    Hardware seems to work (if nothing else is grilled) and I can jump into software.Name:  TESTBOARD1.png
Size:  445.7 KBName:  TESTBOARD2.png
  1. 20MHZ External Oscillator Settings
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 27th October 2011, 01:44
  2. how to configure external oscillator
    By itsssyam in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 12:15
  3. A question on defining the external oscillator
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2009, 14:31
  4. How to use an external oscillator
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 5th February 2008, 14:19
  5. External oscillator and startup
    By RussMartin in forum General
    Last Post: - 17th March 2007, 01:53
