DS1302 ask for and input load chip
Results 1 to 4 of 4
    Nov 2017
    LAS VEGAS NV
    Default DS1302 ask for and input load chip
    All my code works but how do I substitute $30 with my TEMP
    one of my request to get start information:
    SEROUT2 TX, baudrate, ["ENTER HOUR (HH):",13]
    SERIN2 RX, Baudrate, [DEC2 TEMP]
    writing it to the ds1302:
    HIGH RST ' Activate the DS1302
    SHIFTOUT DG, CLK, 0, [$84] ' Send write hour
    SHIFTOUT DG, CLK, 0, [$30] ' Send hours
    LOW RST
    tried a lot of different solutions , but none worked
    thanks for the any help
    Robb
    Nov 2017
    LAS VEGAS NV
    Default Re: DS1302 ask for and input load chip
    thanks to Jamie s This works
    RTCHH=TEMP DIG 1
    RTCHH=RTCHH<<4
    RTCHH=RTCHH+(TEMP DIG 0)
    'writing it to the ds1302:
    SHIFTOUT DG, CLK, 0, [RTCHH] ' Send hours
    LOW RST
    I believe you need to treat the data as Binary Coded Decimal, However if you enter the data as 2 digits of hexadecimal that should work. Just don't enter any alpha digits, ie. ABCDE or F. Try replacing the lines:
    SERIN2 RX, Baudrate, [DEC2 TEMP] with SERIN2 RX, Baudrate, [HEX2 TEMP]
    and
    SHIFTOUT DG, CLK, 0, [$30] ' Send hours with SHIFTOUT DG, CLK, 0, [HEX2 TEMP] ' Send hours
    EN82fn
    will not work
    the value needed to be sent is a packed bcd byte not two hex chrs
    consideration also of the 12/24 hour bit must be considered also
    simple way to convert binary hour value in tmp to packed bcd in hour
    HOUR = ((tmp / 10) << 4) + (tmp // 10) ; bin to bcd
  1. Replies: 8
    Last Post: - 22nd January 2016, 18:27
  2. DS1302 Problem, again :(
    Last Post: - 4th May 2014, 10:34
  3. Can you use the same pin as input/output and control led load?
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 15th August 2013, 09:28
  4. DS1302 and 18F452
    By Astro in forum mel PIC BASIC
    Last Post: - 9th May 2006, 22:02
  5. Ds1302
    By willie in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2005, 18:04
