NCO Glitch
Results 1 to 4 of 4
Thread: NCO Glitch
    OK
    Default NCO Glitch
    I'm sending NCO values from one PIC to another. The Comm protocol requires 2 bytes per NCO1INCx register; 1st identifies it, 2nd is the NCO1INCx value. Finally there is a "Start" command byte sent. I noticed shooting for 2.4 MHz that I only got 564 Hz. However, if I turn the NCO Module Off, then On again, I get the 2.4 MHz. Here is the code for the Receiver:
    DEFINE  OSC         8
    DEFINE  HSER_RCSTA  90h             ;Enable serial port & continuous receive
    DEFINE  HSER_TXSTA  02h             ;Disable transmit, BRGH = 0
    DEFINE  HSER_CLROERR 1              ;Clear overflow automatically
    DEFINE  HSER_BAUD   9600
    ;Configurations:
        __config _CONFIG2, _MCLRE_OFF & _PWRTE_OFF & _WDTE_ON & _LPBOREN_OFF & _BOREN_ON & _BORV_LOW & _PPS1WAY_OFF & _STVREN_ON & _DEBUG_OFF
        __config _CONFIG3, _WRT_OFF & _LVP_OFF
        __config _CONFIG4, _CP_OFF & _CPD_OFF
    ;Aliases:
    ;Prb        VAR     LATA.0		       ;HF Generator Driver for Probes
    ;RX         VAR     PORTA.1		       ;USART Receive
    ;TX         VAR     PORTA.2		       ;USART Transmit
    ;MCLR       VAR     PORTA.3		       ;!MCLR
    ;NC         VAR     PORTA.4		       ;
    ;Wand       VAR     LATA.5 		       ;HF Generator Driver for IR LEDs
    ;Special Function Registers:
    OSCCON1     =   %00000010                   ;INTTOSC, 1:4 Divider, 8 MHz
    OSCFRQ      =   %00000011                   ;8 MHz
    TRISA       =   %00001110
    ANSELA      =   0
    WPUA        =   0
        PPSLOCK = $55
        PPSLOCK = $AA
        PPSLOCK = 0                             ;Unlock PPS
    ;RA0PPS      =   %00011101                   ;Sets NCO Output to RA0, Pin 7
    ;RA5PPS      =   %00011101                   ;Sets NCO Output to RA5, Pin 2
    RA2PPS  	=   %00010100                   ;Sets USART TX to RA2, Pin 5
    RXPPS       =   %00000001                   ;Sets USART RX to RA1, Pin 6
        PPSLOCK = $55
        PPSLOCK = $AA
        PPSLOCK = 1                             ;Lock PPS
    NCO1CON     =   %10000000
    NCO1CLK     =   1                           ;NCO1 Clock = Fosc
    PMD0        =   %01000101
    PMD1        =   %00000101
    PMD2        =   %01100110
    PMD3        =   %01110011
    PMD4        =   %00000000
    PMD5        =   %00000111
    VREGCON     =   3                           ;Lowest Power in SLEEP Mode
    CPUDOZE     =   %10100100
    INTCON      =   %01000000
    TX1STA      =   %00000010                   ;$02
    RC1STA      =   %10010000                   ;$90
    BAUD1CON    =   %00000010
    SP1BRGL     =   $0C                         ;Decimal 12, Yields 9600 BAUD
    PIE1.5      =   1                           ;RCIE, USART Receive Flag
    ;Variables:
    NcoL        VAR     BYTE BANK0 SYSTEM       ;USART NCO1INCL Value
    NcoH        VAR     BYTE BANK0 SYSTEM       ;USART NCO1INCH Value
    NcoU        VAR     BYTE BANK0 SYSTEM       ;USART NCO1INCU Value
    Rec         VAR     BYTE BANK0 SYSTEM       ;USART Receive Register Value
    ;Constants:
    Begin       CON     %10010000               ;USART Command to Start NCO, $90
    Halt        CON     %10010001               ;USART Command to Stop NCO, $91
    IR          CON     $92                     ;USART Command to Set NCO Output to LATA.5
    Prb         CON     $93                     ;USART Command to Set NCO Output to LATA.0
    NcoL_Val    CON     %10000001               ;USART Command, Following is NcoL, $81
    NcoH_Val    CON     %10000010               ;USART Command, Following is NcoH, $82
    NcoU_Val    CON     %10000011               ;USART Command, Following is NcoU, $83
    ;Labels:
        PIR1.5 = 0
        PAUSE 50
    DO
        DO
            LOOP WHILE PIR1.5 = 0
        GOSUB Orders
    LOOP
    Run:
    DO
        IF PIR1.5 = 1 THEN
            GOSUB Orders
        PAUSE 1
    LOOP
    Slumber:
        NCO1CON.7 = 0
    @   DOZE
    @   NOP
    GOTO Main
    Orders:
        HSERIN [Rec]
    ;   Rec = RC1REG
        SELECT CASE Rec
            CASE IS = $81
                HSERIN [NcoL]
                NCO1INCL = NcoL
            CASE IS = $82
                HSERIN [NcoH]
                NCO1INCH = NcoH
            CASE IS = $83
                HSERIN [NcoU]
                NCO1INCU = NcoU
            CASE IS = $90
                STKPTR = STKPTR - 1
                PIR1.5 = 0
                NCO1CON.7 = 1.  ;Turn NCO On
                PAUSE 500
                NCO1CON.7 = 0. ;Turn NCO Off
                PAUSE 500
                GOTO Run
            CASE IS = $91
                STKPTR = STKPTR - 1
                PIR1.5 = 0
                GOTO Slumber
            CASE IS = $92
                PPSLOCK = $55
                PPSLOCK = $AA
                PPSLOCK = $55
                PPSLOCK = $AA
                TRISA.0 = 1                             ;Shuts Down Alt Pin LATA.0
            CASE IS = $93
                PPSLOCK = $55
                PPSLOCK = $AA
                PPSLOCK = $55
                PPSLOCK = $AA
                TRISA.5 = 1                             ;Shuts Down Alt Pin LATA.5
        END SELECT
        PIR1.5 = 0
    There is a slight delay in getting the 2.4 MHz output, which for this application is acceptable. Just wondering if I might have overlooked something simple.
    Aug 2011
    Default Re: NCO Glitch
    Swap the order you're writing to the registers... U, H, then L.
    When the NCO module is enabled, the NCO1INCU and
    NCO1INCH registers should be written first, then the
    NCO1INCL register. Writing to the NCO1INCL register
    initiates the increment buffer registers to be loaded
    simultaneously on the second rising edge of the
    NCO_clk signal.
    The registers are readable and writable. The increment
    registers are double-buffered to allow value changes to
    be made without first disabling the NCO module.
    When the NCO module is disabled, the increment
    buffers are loaded immediately after a write to the
    increment registers.
    OK
    Thank you, I'll try that.
    OK
    Thanks Tumbleweed! That did the trick. Reversed the order of the Send, removed the On-Off-On in the Receiver, get my correct output right out the gate.
  1. NCO Calculator
    By mpgmike in forum Code Examples
    Last Post: - 27th January 2020, 16:04
