Icsp
Results 1 to 3 of 3
Thread: Icsp
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Icsp
    Hello all. Today's question is about ICSP.
    Is there a fixed standard for ICSP connections or does everyone have their own design. As far a I can figure out, the required connections are MCLR, RB7, RB6 and 0v. I have seen some connected to RB3 as well, but I believe that is only for Low Voltage Programming?.
    The EPIC programmer does not use PB3 and that is what I have been using, but I am changing programmers and I suspect that even though they show a PB3 connection, I can get away with just the other 2 port lines as long as I am NOT using Low Voltage Programming.
    Thanks for your help folks.
    Peter Moritz.
    Jun 2005
    Wisconsin
    It is a standard. RB3 is the monitoring connection used for debugging. If you just programming the pic you don't need RB3.
    http://www.melabs.com/support/icsp.htm
    look the explantion right to some MCU #
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 17:31
  2. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 20:13
  3. Soic Icsp
    Last Post: - 13th September 2008, 19:51
  4. Replies: 1
    Last Post: - 10th December 2007, 23:57
  5. 16F819 ICSP programming
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 31st October 2004, 10:15
