problem with LCD large Numbers
Results 1 to 6 of 6
    Default Re: problem with LCD large Numbers
    Richard:
    Thanks for your response. I modified your program to use with a 18F14K22, and since I have a serial LCD backpack, I changed the LCD stuff to SEROUT2. Also, no PB3 here, still on 2.6, but the program works great. Got 4 Warnings regarding the assembly stuff, I will try to figure that out, but the program runs just fine.
    My intent in developing this program was to have a routine to add to my programs that use LCD's with some numeric display requirements.
    I still plan on spending some (a little) time on my original program, to try to figure out the problem - hate to have an error like that that I do not understand.
    once again THANKS
    ozarkshermit, Attached is a program I wrote quite a few years ago to test the theory of using BIG numbers on a 4 x 20 LCD display. Enjoy...
    EN82fn
    Aug 2003
    Your Z loop increments Z by 6 for each iteration.
    You increment Z by 5 manually within the loop, and the NEXT Z used to close the loop iterates another 1.
    If you take the difference between your start and end indexes for each digit A and B,
    the difference between A and B for digit zero is the only set that is evenly divisible by 6.
    The other digits overshoot the loop index by 2.
    Oct 2009
    Utah, USA
    You might also check this thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=17707
    good luck
    Dwight
    Dwight
  1. Math problem with PBP 2.6 and 18F4550, large numbers
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2013, 04:41
  2. handling Large Numbers
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 26th April 2007, 02:33
  3. Multiplying large numbers
    By jhonea1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2006, 17:41
  4. How to display large numbers
    Last Post: - 26th March 2006, 23:17
  5. math problems - large numbers
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 16th February 2004, 07:48
