SSD1306 INCLUDE for PBP3
Results 1 to 40 of 102
    Default Re: SSD1306 INCLUDE for PBP3
    That is nice! Is there any post on the forum how this can be done?
    This needs 2304 bytes for 6 pieces and I think this can be managed.
    LCDAssistant.exe
    GLCDtool.exe
    will get you close [keep height to multiple of 8]
    found this example
    '*  Name    : ssd1306_DEMO.PBP                                   *
    '*  Author  : richard                                            *
    '*  Notice  :                                                    *
    '*  Date    : 19/11/2017                                         *
    '*  Version :                                                    *
    '*  Notes   :                                                    *
    '*          :FOR pic 18F26K22              SSD1306               *
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = OFF
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    DEFINE OSC 64
    char var byte
    x    var byte
    y    var byte
    BUFF VAR BYTE[16]
    NCO_INT     VAR WORD
    OSCCON = %01110000
    ANSELb = 0
    ANSELA = 0
    ANSELC = 0
    OSCTUNE.6=1
    ;use this define for hw i2c
    #define hwi2c 1
    ;set and uncomment these to use softi2c
    'SCL var PortC.3      ' I2C Clock
    'SDA var PortC.4      ' I2C Data
    ;set these  to match display
    ssdheight con 7      ; 7 = 8 PAGES  64*128 ,  3 = 4 pages 32*128
    ssdwidth  con 127    ; 128 PIXELS WIDE
    sdd1306_addr con $78
    Include "ssd1306_I2C.INC"  ' bring it in
    include "font7x5_18.bas"
    gosub glcd_init
    BIG_TEXT = 0
    looper:
        GLCD_CLR
        SSDBM 30,0,64,64 ,kooka
        PAUSE 1000
        GLCD_CLR
        SSDBM 30,0,61,64 ,surfer64
        PAUSE 1000
        GLCD_CLR
        SSDBM 30,0,64,64 ,lizard64
        PAUSE 1000
        GLCD_CLR
        GLCDDHL 0,0,75,1       ;x,y,len,patten
        GLCDDHL 0,2,75,128
        GLCDDVL 0,0,3           ;x,y,height [in pages]
        GLCDDVL 75,0,3
        GLCDSTR  5,1,"--SSD1306--"   ;x,y, cont string
        ARRAYWRITE BUFF,["ABCDEF",0]
        CHAR="!"
        GLCDC 100,1,CHAR             ;x,y , chr
        BIG_TEXT = 1
        if ssdheight > 3  then
            GLCDSTR  2,4,BUFF
            ARRAYWRITE BUFF,["@12456-=#",0]
            BIG_TEXT = 0
            GLCDSTR  2,7,BUFF          ;x,y ,str buffer [null terminated]
            GLCD_CLR
            GLCDSTR  2,0,BUFF
            BIG_TEXT = 0
            GLCDSTR  2,3,BUFF
        PAUSE 1000
    GOTO looper
    kooka:
    @ db 0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0, 128
    @ db 224, 240, 248, 248, 248, 248, 252, 220, 220, 220, 220,  28,  28,  28,  28,  28
    @ db 124, 248, 248, 248, 240, 192, 128,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,  64, 224, 240, 240, 216, 248, 248, 232, 236, 172, 183
    @ db 183, 183, 183, 159, 191, 191, 159,  31,  63,  63,  28,  62,  62,  63,  28,  28
    @ db 0, 128, 225, 255, 255, 255, 255, 124,   0,   0,   0,   0,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,   0,   0,   0,   1,   1,   1,   1,   1,   1,   0,   0
    @ db 0,   0,   1,   3,  15,  63, 143,   0,   0,   0,   0,   0,   0, 140,  30, 214
    @ db 231, 227, 243, 251, 249, 252, 252, 252, 254, 254, 255, 124, 240, 240, 192,   0
    @ db 0,   0,   0,   0,   0,   0,   0,   0,   0, 128, 128, 128,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,   3,  15, 248, 128,   6,  62, 255, 255, 191, 191, 255
    @ db 207, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
    @ db 252, 128,   0,   0,   0,  24, 248, 252, 255, 255,  15,   7,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,   0,   0, 192, 112, 248, 248, 248, 248, 248, 248, 254
    @ db 254, 254, 254, 246, 254, 252, 248, 193,  15,  30, 252, 240, 225, 199, 207, 158
    @ db 63, 127, 254, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
    @ db 255, 255, 254,  62,  30,  31,  31,  15,  15,  15,   0,   0,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,   0,   0,   0,   3,   3,  31,  31,   7,   7,  15,  63
    @ db 127,  63,   7,  15,  15, 127, 255, 247, 198, 192, 248, 124,  29,  31, 159, 159
    @ db 223, 254, 252, 253, 249,  51, 247, 239, 255, 255, 255, 255, 255, 255, 255, 255
    @ db 255, 255, 255, 255,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0, 224, 127,  15, 128, 224, 248, 252, 127,  31,  15,  15
    @ db 7,   7,   7,   7,   3,   0,   0,   0,   0,   3,  63, 254, 255, 255, 125, 251
    @ db 255, 223, 222, 254, 206, 224, 128,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db 0,   0,   0,  12,  31,  63, 112, 252, 255, 127,  31,   1,   0,   0,   0,   0
    @ db 0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   7,  63, 126, 127
    @ db 127, 255, 189, 223, 255,  55,  31,   0,   0,   0,   0,   0,   0,   0,   0,   0
    surfer64 :
    @ db   0,   0,   0,   0,   0,   0,    0,    0,   0,   0,   0,   0,   0,   0,    0 , 252
    @ db   254, 254, 255, 254, 254, 254,  16,   0,   0,   0,   0,   0,   0,   0,    0,   0
    @ db   0,   0,   0,   0,   0,   0,    0,    192, 224, 240, 248, 252, 248, 255,  255, 255
    @ db   255, 253, 249, 240, 248, 240,  240,  224, 224, 192, 192, 192, 192, 192,  128, 192
    @ db   128, 192, 128, 192, 192, 192,  192,  192, 0,   0,   0,   0,   0,   0,    0,   0
    @ db   0,   128, 252, 255, 95,  15,   7,    63,  255, 255, 255, 255, 255, 255,  255,  63
    @ db   31,   2,   0,   0,   1,   1,   1,   1,   1,   3
    @ db   1,   3,   1,   1,   1,   1,   1,   1,   1,   1,   1,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   0,   0, 170, 255, 255, 225, 128,   0,   0, 253, 255
    @ db   255, 255, 255, 255, 255, 240, 192, 192, 128,   0,   0,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   3,   3,   1,   0,   0,   0,   1,   3,   7
    @ db   7,  31,  63, 127, 255, 255, 255, 255, 255, 254, 252, 240, 224,   0,   0,   0
    @ db   0,   0, 192, 192,   0, 112, 240, 240,   0,   0,  96, 184,  28, 224, 192, 128, 224
    @ db   224,   0,   0,  84, 255, 255, 255,  31,   1,   7,  63, 127, 255, 255, 248,  64
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db   16,  16, 145, 147,  83, 182, 117, 165,  53,  43,  77, 106, 235, 227, 231, 252, 243
    @ db   239, 240, 224, 255, 255, 255, 193, 192, 192, 192, 128, 192, 131, 223, 255, 255, 248
    @ db   192, 128,   0, 128,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db   0,   0,   4,  14,   6,   6,   6,   6,   5,  13,  29,  26,  22,  22,  21,  21,  21
    @ db   21,  21,  13,  91, 123,  87,  87,  87, 215,  87, 255,  87, 255,  87, 207,  95, 191
    @ db   223, 159, 159, 159,  95, 159,  95, 127,  95,  95,  95,  95,  95,  79,  87,  47,  23
    @ db   27,  27,   9,   5,   4,   4,   4,   4,   4,   4
    lizard64  :
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   192
    @ db   0,   0, 192,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   248, 128, 253, 192
    @ db   112, 158,  65, 32,  0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   128, 192, 224, 248, 224, 80,  88,  76,  32
    @ db   16,  0,   0,   128, 192, 224, 240, 240, 240, 248, 252, 60,  16,   0,  0,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   17, 127, 127,  127
    @ db   127, 105, 116, 240, 240, 248, 248, 248, 248, 152, 128, 192, 192, 192, 192, 224
    @ db   192, 224, 228, 238, 255, 255, 255, 255, 253, 251, 251, 241, 241, 241, 241, 248
    @ db   248, 252, 124,  63,  31,  15, 7,   7,   7,   3,   1,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   0,   128, 192, 224, 240, 240
    @ db   248, 252, 254, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
    @ db   127, 63,  63,  63,  63,  63,  31,  31,  31,  15,  95,  255, 255, 255, 223, 207
    @ db   195, 128, 128, 128, 192, 160, 128, 128, 128, 128, 0,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   128, 240, 248, 252, 254, 127, 31,  15,  7,   7,   3
    @ db   1,   1,   1,   0,   6,   7,   7,   7,   7,   15,  31,  31,  31,  63,  31,  63
    @ db   21,  23,  21,  21,  21,  20,  20,  20,  20,  0,   0,   0,   0,   0,   1,   1
    @ db   1,   3,   3,   7,   15,  31,  39,  14,  3,   10,  2,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   224, 255, 255, 255, 15,  1,   0,   0,   0,   0,   0,   0,   0
    @ db   0,   0,   0,   128, 192, 96,  96,  48,  16,  16,  16,  8,   0,   0,   0,   0
    @ db   0,   0,   0,   0,   7,   63,  127, 248, 240, 192, 192, 128, 0,   0,   0,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   0,   128, 192, 192, 64,  96,  48,  24
    @ db   28,  6,   7,   3,   1,   0,   0,   0,   0,   0,   0,   0,   0,   6,   6,   0
    @ db   0,   0,   0,   0,   0,   0,   0,   0,   1,   1,   1,   3,   7,   3,   7,   6
    @ db   7,   6,   7,   6,   7,   3,   7,   3,   3,   1,   1,   0,   0,   0,   0,   0
    Got some genuine, 128x128 pixels, 16 shades of grey, OLED displays from Futaba. They use SSD1327. Any chances to adapt all above to that controller?
    no, my tft code would be a closer fit, a full redesign would be needed for the greyscale nibbles. full colour oleds are about the same price so i doubt if i would be interested in grey scale code anyway for such tiny displays.
  1. SSD1306 Include example
    By timc in forum Code Examples
    Last Post: - 28th November 2017, 08:53
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 19:16
  3. Using INCLUDE to add a text file in PBP3
    By Sumobob in forum PBP3
    Last Post: - 16th May 2016, 18:56
  4. PBP3 to include 18F97J94?
    By fowardbias in forum PBP3
    Last Post: - 18th December 2013, 16:42
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 15:40
