PIC10F322 6 pin chip
Results 1 to 8 of 8
    Jan 2022
    Default PIC10F322 6 pin chip
    Hello, I'm currently using the student PBP3 with Micro Code Studio version and I have a project to use some PIC10F322 / 6 pin chips.
    on the devices list of the PBP3 silver edition this PIC it's included, but on the "
    Compare Editions of PICBASIC PRO Compiler" it is listed chips of 8-pin through 64-pin.
    I asked MELAB about this and they reply by sending me the link of the PBP3 edition device list.
    I assume it's will work but like to know just before buying the silver edition.
    Thank's
    Name:  pbp3 editions.jpg
    Oct 2011
    Default Re: PIC10F322 6 pin chip
    There is a list of supported chips on https://pbp3.com/devicelist.html
    Your chip is included
    Jan 2022
    Hello, and thank's for the reply, I know the list it's included, but I'm concern about is the 6 pin chip (not the 8 pin) will work
    this is my request.
    On your free student edition, is the chip you want to use supported?
    In either form. If it is supported then load the hex file and you are done.
    The 6-pin and 8-pin versions are exactly the same only packaged differently.
    The 8-pin package has 2 pins that are N/C so there really is no difference and no reason why it should not work with the silver edition despite the "matrix" saying 8-64pins.
    Jan 2022
    this pic is only on the silver, gold edition.
    anyone got pbp3 codes ?
    let me know,
    thank's to all for help
    What do you mean by "anyone got pbp3 codes ?"
    Jan 2022
    Hello, Ioannis
    I found the config for the OSC, and other.
    now it's working fine
    thank's to all
  1. How to use this IO chip?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 30th April 2013, 19:06
  2. question about the pin to pin connections on a SPI interface
    Last Post: - 4th January 2013, 13:03
  3. 120VAC to 5V chip
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 11th September 2009, 19:00
  4. cHIP LABLING
    By muddy0409 in forum Off Topic
    Last Post: - 25th January 2009, 09:33
  5. Which chip do i use?
    Last Post: - 2nd December 2007, 22:28
