PIC16F18446 - 12 bits ADC gives 16 bits results!!!!
Results 1 to 4 of 4
Threaded View
    SWITZERLAND (french speaking)
    Default PIC16F18446 - 12 bits ADC gives 16 bits results!!!!
    Still going ahead with the PIC16F18446...
    I'm testing the 12 bits ADC.
    First, I had to find out the correspondance between Pin and Channel (I'm using a 20-pin device). Here it is:
    The code I use is here:
    ' PIC 16F18446
        __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT1 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG2, _MCLRE_ON & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
        __config _CONFIG5, _CP_OFF
    ' Oscillator Control Register1
    OSCCON1 = %01100000 ' $60
    ' HFFRQ - Oscillator's Frequency Selection Register
    OSCFRQ  = %00000010 ' 4MHz
    DEFINE ADC_BITS 12   'Number of bits in ADCIN result
    ' ====== VARIABLES =================================================================================
    ADC_Value   var word
    Serial_Out  VAR PORTB.7
    Mode        Var BYTE
    ' ====== INITIALIZE VARIABLES ======================================================================
    Mode        = 84 ' serial com BdRate settings
    ' ====== TEST PROGRAM ==============================================================================
    TEST:
        ADCIN 23, ADC_Value ' ADC channel 23 is RC7
        Serout2 Serial_Out,Mode,["ADC in: ", dEC ADC_Value,13,10]
        PAUSE 500
        GOTO TEST
    Now, the strange thing is: where I expect a 12 bits result (0..4095), I get a 16 bits value 0..65520 as result and it's amazingly steady, not a digit variation!!!
    I'm using a 10 turns 10kOhms pot and that's all.
    How can that be please?
    Roger
  1. Parity & Stop Bits settings and results
    By svjohngalt in forum Serial
    Last Post: - 27th January 2018, 20:16
  2. Replies: 2
    Last Post: - 23rd April 2013, 16:34
  3. Incorrect adc channel bits generated
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 6th February 2010, 18:56
  4. DT_INTS-14 /interrupts enable bits / flag bits
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 18:42
  5. parsing adc word into bits
    By GREYBIRDMAN in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 21:08
