SSD1306 INCLUDE for PBP3
Results 1 to 40 of 102
    Default Re: SSD1306 INCLUDE for PBP3
    OK. Later I will do that. But all what I described is from this thread starting from post #1 and on.
    i know but some errors crept in and some posted files are not right and i cannot fix them nor remember which ones they are
    its best to be dealing from the same deck
    Yes you are right. Will post that later today.
    Merry Xmas to all.
    here are the files I used to test the SSD1306 lcd.
    Just tested the new include you post and works with soft I2C as expected. But not on hardware I2C...
    My code with new include:
        CONFIG  PLLDIV = 1            ; Divide by 5 (20 MHz oscillator input)
        CONFIG  CPUDIV = OSC1_PLL2    ; [Primary Oscillator Src: /1][96 MHz PLL Src: /2]
        CONFIG  USBDIV = 2            ; USB clock source comes from the 96 MHz PLL divided by 2
        CONFIG  FOSC = ECPLLIO_EC     ; HSPLL_HS       ; HS oscillator, PLL enabled (HSPLL)
        CONFIG  PWRT = OFF            ; PWRT disabled
        CONFIG  BOR = ON              ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 3              ; Minimum setting
        CONFIG  VREGEN = ON           ; USB voltage regulator enabled
        CONFIG  WDT = ON              ; WDT enabled
        CONFIG  WDTPS = 512           ; 1:512
        CONFIG  CCP2MX = ON           ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<4:0> pins are configured as digital I/O on Reset
        CONFIG  LPT1OSC = OFF         ; Timer1 configured for higher power operation
        CONFIG  MCLRE = ON            ; MCLR pin enabled; RE3 input pin disabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  ICPRT = OFF           ; ICPORT disabled
        CONFIG  DEBUG = OFF           ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
        CONFIG  CP0 = OFF             ; Block 0 (000800-001FFFh) is not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (002000-003FFFh) is not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (004000-005FFFh) is not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (006000-007FFFh) is not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) is not code-protected
        CONFIG  CPD = OFF             ; Data EEPROM is not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-001FFFh) is not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (002000-003FFFh) is not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (004000-005FFFh) is not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (006000-007FFFh) is not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) are not write-protected
        CONFIG  WRTB = OFF            ; Boot block (000000-0007FFh) is not write-protected
        CONFIG  WRTD = OFF            ; Data EEPROM is not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot block (000000-0007FFh) is not protected from table reads executed in other blocks
    DEFINE OSC 48
    LATA = %00000000
    LATB = %00000000
    LATC = %00000000
    LATD = %00000000
    LATE = %00000000
    TRISA = %00100001
    TRISB = %00010000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    ;           ADC Settings
    ADCON0=%00000001
    ADCON1=%00001110
    ADCON2=%10100111
    cmcon=0
     ' Set LCD Data port
    DEFINE LCD_DREG PORTD
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTD
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 0
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTD
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 1
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    'DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    'DEFINE LCD_DATAUS 50
    DEFINE ADC_BITS 10 ' Set number of bits in result
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    DEFINE ADC_CLOCK 3
    t1con=0
    char var byte
    x    var byte
    y    var byte
    BUFF VAR BYTE[16]
    ;use this define for hw i2c
    #define hwi2c 1
    ;set and uncomment these to use softi2c
    SCL var Portb.1      ' I2C Clock
    SDA var Portb.0      ' I2C Data
    ;set these  to match display
    ssdheight con 7      ; 7 = 8 PAGES  64*128 ,  3 = 4 pages 32*128
    ssdwidth  con 127    ; 128 PIXELS WIDE
    sdd1306_addr con $78
    Include "ssd1306_I2C_16_18.INC"  ' bring it in
    include "font7x5_18.bas"
    '==========================    MAIN  Routine    ==============================
    gosub glcd_init
    BIG_TEXT = 0
    looper:
        GLCD_CLR
        GLCDDHL 0,0,75,1       ;x,y,len,patten
        GLCDDHL 0,2,75,128
        GLCDDVL 0,0,3           ;x,y,height [in pages]
        GLCDDVL 75,0,3
        GLCDSTR  5,1,"--SSD1306--"   ;x,y, cont string
        ARRAYWRITE BUFF,["JBCDEF",0]
        CHAR="!"
        GLCDC 100,2,CHAR             ;x,y , chr
        BIG_TEXT = 1
        if ssdheight > 3  then
            GLCDSTR  2,4,BUFF
            ARRAYWRITE BUFF,["@12456-=#",0]
            BIG_TEXT = 0
            GLCDSTR  2,7,BUFF          ;x,y ,str buffer [null terminated]
            GLCD_CLR
            GLCDSTR  2,0,BUFF
            BIG_TEXT = 0
            GLCDSTR  2,3,BUFF
        PAUSE 3000
    GOTO looper
    it works for me with
    TRISB = % 00010011
    most pic modules that switch pin directions like to control tris themselves, the data sheet for this chip is totally not clear
    at all re i2c tris requirements
    Yes, you are right. I took it for granted that this was taken care in the include file. Now it works OK with hard I2C also.
    Next, how to import the 16x16 characters into the 5x7 library.
    Can these co-exist?
    I tried to add your pawn example after the 5x7 data but obviously this does not work if one wants to print character 128...
    I attach my failed try.
  1. SSD1306 Include example
    By timc in forum Code Examples
    Last Post: - 28th November 2017, 09:53
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 20:16
  3. Using INCLUDE to add a text file in PBP3
    By Sumobob in forum PBP3
    Last Post: - 16th May 2016, 19:56
  4. PBP3 to include 18F97J94?
    By fowardbias in forum PBP3
    Last Post: - 18th December 2013, 17:42
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
