Using the Mecanique Bootloader without the DTR reset signal
Results 1 to 3 of 3
    Lightbulb
    Quote Originally Posted by picnaut
    Now, if you're not handling serial port communication all of the time, you are going to have to at least check the receive buffer every second or so to see if the "request-to-send" character has been received (the bootloader software will send if many times).
    Actually, I did some more experimenting and found that you can go up to a minute without checking the serial port. The bootloader sends out the request for quite a while. However, to be on the safe side, I would check for that character at least every 30 seconds.
    ---> picnaut
    Apr 2005
    Talking
    very nice! I just tried it on a project of mine and it works like a champ. Thanks alot for the info
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
