Count RB0... on RB7
Results 1 to 23 of 23
    Mentor, Ohio
    Smile
    Hi Leonardo,
    Mr E. has done a great job (As usual!) of providing code for you. But if you wired your project as shown in the drawing then this is where you are having the difficulty.
    In your .bmp image you show using pull down resistors. This means your inputs are at 0vdc until the button is pressed and when you press the push button you are applying +5vdc. Your code is looking for 0v to create the activity to occur.
    "if clreep=0 then ' is ClrEEP pushbutton is pressed
    write 0,0 ' Reset the pulse count in EEPROM
    led=1 ' LED = ON
    pause 1000 ' wait 1 sec
    led=0 ' LED=OFF
    endif '
    Read 0, Apulse ' Read count from internal eeprom
    repeat
    if clkin=0 then
    while clkin=0 : wend
    pause 50"
    Turn on the internal weak pull ups and tie the other end of your push buttons to ground. To protect the PIC's inputs put 100 ohm resistors in line with the swtich and also tie MCLR to +5vdc through a 1k resistor.
    This should solve your problem.
    BobK
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Timer RB0...RB7 on RA1
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 01:38
  4. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
  5. Count RB0... on RB7
    Last Post: - 26th August 2005, 00:13
