Count RB0... on RB7
Results 1 to 23 of 23
    Smile
    Hello mister e,
    Excellent the code but like you reset the eeprom from some pin?.
    Quote Originally Posted by mister_e
    to prevent adding any additional hardware to save count result when you remove the power, use the following
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
        TRISB=%00000001     ' Set RB0 to input, others to output
        OPTION_REG.7=0      ' Enable internal pull-up on PORTB
        LED    VAR PORTB.7  ' connected between RB7 and GND via resistor
        ClkIn  var PORTB.0  ' connected between RB0 and GND
        Apulse VAR BYTE     ' store the amount of pulse
        Data @0,0 ' set count @ 0 at programming time
        led=0
        Read 0, Apulse ' Read count from internal eeprom
        repeat
            if clkin=0 then
                while clkin=0 : wend
                pause 50
                apulse=apulse+1
                WRITE 0,apulse ' save count in the internal EEPROM
            until apulse=10
        led=1
    Here:
        goto here
    this should work
    One of the various method to do it
        TRISB=%00000011     ' Set RB0,RB1 to input, others to output
        ClrEEP var PORTB.1  ' connected between RB1 and GND
        led=0               ' LED=OFF
        '   To Reset the value in the EEPROM, press on ClrEEP button while
        '   applying power. When the command is accepted, the LED will
        '   stay ON for 1 second
        if clreep=0 then ' is ClrEEP pushbutton is pressed
            write 0,0    ' Reset the pulse count in EEPROM
            led=1        ' LED = ON
            pause 1000   ' wait 1 sec
            led=0        ' LED=OFF
            endif        '
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    Smile Thanks
    Hello mister e,
    Thank you for their help and I hope to be able to have their support in future occasions.
    Leonardo
        led=0               ' LED=OFF
            led=1        ' LED = ON
            led=0        ' LED=OFF
            endif        '
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    Smile
    Hello mister e,
    Because uses, Here
    goto here..... I don't understand it.
    Quote Originally Posted by Leonardo
    Hello mister e,
    Leonardo
    Smile
    Hello mister e,
    As I avoid the rebounds of the pulsador?.
    Hello mister e,
    Because uses, Here
    Smile
    Hello mister e,
    In the following code it does add an entrance and an exit but, in RB1 and out RB6, but don't I achieve that each exit works in independent way that can happen?, like I can store the two values in the eeprom?.
    TRISB=%00001111 ' Set RB0 to input, others to output
    LED1 VAR PORTB.6
    BOT VAR PORTB.1
    Apulse1 var byte
    led=0
    apulse=0
    led1=0
    Apulse1=0
    paso1:
    repeat
    if clkin=0 then
    apulse=apulse+1
    until apulse=7
    led=1
    paso2:
    repeat
    if BOT=0 then
    while BOT=0 : wend
    apulse1=apulse1+1
    until apulse1=5
    led1=1
    Here:
    goto here
        led=0               ' LED=OFF
            led=1        ' LED = ON
            led=0        ' LED=OFF
            endif        '
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    Default ???????`
    I tried to understand but and i'm still not sure of the question. BTW i did the following, let me know if it do what you're looking for. Case not, let me know in more details or with a drawing. Sometimes it help my single brain cell to figure out the question
        LED1    VAR PORTB.6
        BOT     VAR PORTB.1
        Apulse1 var byte
        data @0,0,0
        read 0,apulse
        read 1,apulse1
        led = 0
        led1= 0
    paso1:
        repeat
            if clkin=0 then
                apulse=apulse+1
                write 0,apulse
            if BOT=0 then
                while BOT=0 : wend
                apulse1=apulse1+1
                write 1,apulse1
            until (apulse=7) or (Apulse1=5)
        if apulse=7 then
            led=1
                led1=1
        goto paso1
    Smile
    Hello mister e,
    I sit down it it mistakes, the following code works OK, what I want is to put another entrance RB1 to count the pulses and another exit RB6 and that it stores them in the eeprom.
    Thank you
    the code :
    led=0 ' LED=OFF
    led=1 ' LED = ON
    led=0 ' LED=OFF
    endif '
    repeat
    if clkin=0 then
    pause 50
    apulse=apulse+1
    until apulse=10
    led=1
    Here:
    goto here
        LED1    VAR PORTB.6
        BOT     VAR PORTB.1
        Apulse1 var byte
        data @0,0,0
        read 0,apulse
        read 1,apulse1
        led = 0
        led1= 0
    paso1:
        repeat
            if clkin=0 then
                apulse=apulse+1
                write 0,apulse
            if BOT=0 then
                while BOT=0 : wend
                apulse1=apulse1+1
                write 1,apulse1
        if apulse=7 then
            led=1
                led1=1
        goto paso1
    Smile
    Hello mister e,
    The code to count and to store the I finish pulse in the eeprom this very well, what I want is to add the same thing in RB1 and RB6 and it also stores it in the eeprom.
    Thank you
    led=0
    repeat
    if clkin=0 then
    pause 50
    apulse=apulse+1
    until apulse=10
    led=1
    Here:
    goto here
    Hello mister e,
    Thank you
    the code :
    led=0 ' LED=OFF
    led=1 ' LED = ON
    led=0 ' LED=OFF
    endif '
    repeat
    if clkin=0 then
    pause 50
    apulse=apulse+1
    until apulse=10
    led=1
    Here:
    goto here
    Smile
    Hello to all,
    Somebody can help me with this please.
    Thank you
    Smile
    Hello mister_e
    As I can modify the value of the count using the eeprom and a lcd?.
    Thank you
        LED1    VAR PORTB.6
        BOT     VAR PORTB.1
        Apulse1 var byte
        data @0,0,0
        read 0,apulse
        read 1,apulse1
        led = 0
        led1= 0
    paso1:
        repeat
            if clkin=0 then
                apulse=apulse+1
                write 0,apulse
            if BOT=0 then
                while BOT=0 : wend
                apulse1=apulse1+1
                write 1,apulse1
        if apulse=7 then
            led=1
                led1=1
        goto paso1
    Smile
    Some suggestion
    Leonardo,
    i know it's really hard for you to write in english but can you provide much details. I try to understand what you say but i'm really lost.
    If you want, post your question in your language, probably someone else here can give us a hand and translate to english.
    I just know english(a few) and French. i'm really sorry Leonardo
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Timer RB0...RB7 on RA1
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 01:38
  4. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
  5. Count RB0... on RB7
    Last Post: - 26th August 2005, 00:13
