Count RB0... on RB7
Results 1 to 23 of 23
    here's one method using interrupt
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
        TRISB=%00000001     ' Set RB0 to input, others to output
        OPTION_REG=0        ' Enable internal pull-up on PORTB
                            ' Interrupt on falling edge of RB0
        INTCON = %10010000  ' Enable global interrupt
                            ' Enable RB0 interrupt
        LED    VAR PORTB.7  ' connected between RB7 and GND via resistor
        ClkIn  var PORTB.0  ' connected between RB0 and GND
        INTF   var INTCON.1 ' RB0 Interrupt flag
        Apulse VAR BYTE     ' store the amount of pulse
        on interrupt goto CountPulses
        led=0
        apulse=0
    start:
        if apulse<10 then start
            '   Here we got the 10 pulses
        INTCON = 0  ' disable all interrupt
        led=1       ' enable the LED
    Z:  goto z      ' stay here 'till next system reboot
    disable
                                     CountPulses:
        '   Here is where the program jump every time the push-buton on
        '   RB0 is press.
        apulse=apulse+1       ' add a count
        while clkin=0 : wend  ' wait untill the push button is release
        pause 50              ' debounce time
        intf=0                ' reset interupt flag
        resume                ' Get out of here
    enable                    ' re-enable interrupt
    without interupts but a loop.
        OPTION_REG.7=0      ' Enable internal pull-up on PORTB
        led=0
        apulse=0
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    Using internal counter(TMR0) and polling TMR0 overflow flag and RA.4 as input instead of RB0
        TRISB=0              ' Set output to all i/o
        TRISA=255            ' set input to all
        OPTION_REG=%11111000 ' TMR0 clock source = RA4
                             ' increment counter on high to low transistion
                             ' prescaller assign to WDT
                             ' prescaller rate 1:1
        CMCON=7              ' disable analog comparator
        INTCON = %00100000   ' enable TMR0 overflow interrupt
        T0IF   var INTCON.2  ' TMR0 Interrupt flag
        TMR0=246             ' pre-load TMR0 to have an Interrupt after 10 pulses
                             '     TMR0 is a 8 byte Register so 246+10=256=interrupt
        led=0
        WHILE T0IF=0 : WEND
        LED=1
    Z:  GOTO Z
    Almost the same as above but polling only the TMR0 register
        TMR0=0
        led=0
        WHILE TMR0<10 : WEND
        LED=1
    Z:  GOTO Z
    I prefer the last one, produce really tight code and easy to understand BUT if the pulse come from a PUSH-Button it can glow the LED before 10 human press as it don't provide any debounce solution. BUT if you add a 0.1-1uF in parrallel, it seems to be enough to do the job. Don't forget the pull-up resistor on the RA.4 pin. Let's say 10K as a standard value
    That should be more than enough to start
    Smile
    Thank you for your orientation
    Quote Originally Posted by mister_e
        led=0
        apulse=0
    start:
    disable
                                     CountPulses:
        '   RB0 is press.
        led=0
        apulse=0
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
        led=0
        WHILE T0IF=0 : WEND
        LED=1
    Z:  GOTO Z
        TMR0=0
        led=0
        LED=1
    Z:  GOTO Z
    Smile
    Hello mister e
    As you it can store the I number of pulses in the eeprom to continue the count if the pic is off?.
    Quote Originally Posted by Leonardo
    to prevent adding any additional hardware to save count result when you remove the power, use the following
        Data @0,0 ' set count @ 0 at programming time
        led=0
        Read 0, Apulse ' Read count from internal eeprom
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
                WRITE 0,apulse ' save count in the internal EEPROM
            until apulse=10
        led=1
    Here:
        goto here
    this should work
    Smile
    Hello mister e,
    Excellent the code but like you reset the eeprom from some pin?.
        led=0
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    this should work
    One of the various method to do it
        TRISB=%00000011     ' Set RB0,RB1 to input, others to output
        ClrEEP var PORTB.1  ' connected between RB1 and GND
        led=0               ' LED=OFF
        '   To Reset the value in the EEPROM, press on ClrEEP button while
        '   applying power. When the command is accepted, the LED will
        '   stay ON for 1 second
        if clreep=0 then ' is ClrEEP pushbutton is pressed
            write 0,0    ' Reset the pulse count in EEPROM
            led=1        ' LED = ON
            pause 1000   ' wait 1 sec
            led=0        ' LED=OFF
            endif        '
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    Smile Thanks
    Hello mister e,
    Thank you for their help and I hope to be able to have their support in future occasions.
    Leonardo
        led=0               ' LED=OFF
            led=1        ' LED = ON
            led=0        ' LED=OFF
            endif        '
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
    Smile
    Hello mister e,
    In the following code it does add an entrance and an exit but, in RB1 and out RB6, but don't I achieve that each exit works in independent way that can happen?, like I can store the two values in the eeprom?.
    TRISB=%00001111 ' Set RB0 to input, others to output
    LED1 VAR PORTB.6
    BOT VAR PORTB.1
    Apulse1 var byte
    led=0
    apulse=0
    led1=0
    Apulse1=0
    paso1:
    repeat
    if clkin=0 then
    apulse=apulse+1
    until apulse=7
    led=1
    paso2:
    repeat
    if BOT=0 then
    while BOT=0 : wend
    apulse1=apulse1+1
    until apulse1=5
    led1=1
    Here:
    goto here
        led=0               ' LED=OFF
            led=1        ' LED = ON
            led=0        ' LED=OFF
            endif        '
        repeat
            if clkin=0 then
                pause 50
                apulse=apulse+1
            until apulse=10
        led=1
    Here:
        goto here
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Timer RB0...RB7 on RA1
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 01:38
  4. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
  5. Count RB0... on RB7
    Last Post: - 26th August 2005, 00:13
