Nextion LCDs... How to comunicate ???
Results 1 to 30 of 30
    Default Re: Nextion LCDs... How to comunicate ???
    The later IDE support animation and video. Maybe you can include these features also?
    LOL I can't make on screen button to change value on some pin, animations? too early
    OK
    The "Basic" series doesn't support these features. You must use the "Intelligent" stuff for that. If using higher end Nextion, you may not need the PIC.
    Yes, I do have a 10" one to test it. The demo that is loaded is very interesting but they do not have it on-line. Unfortunately I have not figured how one can do such a programming on these LCD's.
    These videos are from the demo 10" capacitive LCD.
    Hi mpgmike.
    Do you have any comments about adapting your example code from the magazine article for a PIC18LF26K80 at 64mhz?
    Not sure if I was allowed to post it here? But it is downloadable from the N&V site.
    Thanks Peter
    OK
    The article used a PIC16F18426, because that's what I needed for the Small Engine Ignition Timing Controller. Using a PIC18F would require different CONFIGs and probably different SFR bits, but should work otherwise just talking to the Nextion. The K80 doesn't have enough Timers to do the full Timing Controller project.
    As for those videos, just upload 4 or 8 frames of the moving picture. Use the Timer feature (tm0) with a Variable (va0) to track sequence and the vis command to show each picture in sequence. Timer code should look like this
    if(va0.val==1)
     vis p0,1
     vis p1,0
     vis p2,0
     vis p3,0
    }else if(va0.val==2)
     vis p0,0
     vis p1,1
     vis p2,0
     vis p3,0
    }else if(va0.val==3)
    va0.val+=1
    if(va0.val==5)
     va0.val=1
    Great! Thanks Mike.
  1. Two LCDs on one PIC
    By NavMicroSystems in forum Schematics
    Last Post: - 29th January 2013, 07:56
  2. LCDs
    By Demon in forum Adverts
    Last Post: - 21st April 2012, 03:14
  3. Two LCDs on one PIC
    By lester in forum FAQ - Frequently Asked Questions
    Last Post: - 22nd February 2005, 03:28
  4. Typles of LCDs
    By mslaney in forum General
    Last Post: - 16th December 2004, 15:01
  5. Graphic LCDs
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 20th April 2004, 11:04
