Nextion LCDs... How to comunicate ???
Results 1 to 30 of 30
    Default Re: Nextion LCDs... How to comunicate ???
    You control the LCD through TTL RS232 (only Tx and Rx needed).
    Also you must ensure good +5V/1A to the LCD.
    The rest on the users manual.
    Apr 2015
    Hello Ioannis, thank you for the feedback.
    I did not find examples for PBP on the internet. In the manual there are only examples for uses with Arduino and RaspBerry Pi.
    I could not convert the command used in Arduino to be used in PBP.
    My question is about the serial command format to use.
    Thank you for any help.
    Oct 2009
    From what I can gather it uses a serial connection - so have a look at serial examples for PBP and then adapt them to send the instructions to the device. There is an example here http://support.iteadstudio.com/suppo...cs/11000012477 where someone is using an arduino without any library files, which may help
    You should be able to used hserout command with a PIC that has a UART serial port (most do)
    I also ordered a module, waiting for delivery. Meanwhile, I've downloaded their IDE. Looks like Visual Studio, but so far, I have not managed, how to put my own text on label Very alogical design...
    Mike's tutorial on Nuts n Volts is good starting point.
    Also the tutorials on YouTube are very helpful. There are many that take you step by step.
    OK
    Starting on Page 16:
    http://nutsvolts.texterity.com/nutsv...&folio=16#pg16
    It will be a 7 Part series, next issue: Communication between the Nextion and a PIC (using PBP3)
    Great. I've quit reading N&V a decade ago - too many ads and too many nonsense articles, hope they've changed that....
  1. Two LCDs on one PIC
    By NavMicroSystems in forum Schematics
    Last Post: - 29th January 2013, 07:56
  2. LCDs
    By Demon in forum Adverts
    Last Post: - 21st April 2012, 03:14
  3. Two LCDs on one PIC
    By lester in forum FAQ - Frequently Asked Questions
    Last Post: - 22nd February 2005, 03:28
  4. Typles of LCDs
    By mslaney in forum General
    Last Post: - 16th December 2004, 15:01
  5. Graphic LCDs
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 20th April 2004, 11:04
