PIC18FxxQ43 Version of DT_INTS
Results 1 to 26 of 26
    OK
    Default PIC18FxxQ43 Version of DT_INTS
    A fine Aussie asked me to generate a DT_INTS for the new Q43 series. It has been bench tested with TMR0 and TMR2. My assumption is that if they work, the mechanicals are working, and everything else should work.
    Attached is "working" code for DT_INTS-Q43. It uses the standard ReEnterPBP-18.bas and functions just like previous versions. You must make sure "MVECEN = OFF" in the CONFIG.
    Changes:
    1 - Access Bank is BANK4 in the Q43, not BANK0
    2 - INTCON is INTCON0
    3 - All possible Interrupts are listed along with various #definitions, all non-existent Interrupts have been removed
    4 - ASM movff Commands changed to movffl to work with the extended Memory range
    5 - INTCON0.PIE doesn't exist, I just commented it out.
    Due to #5, this probably only works with all Interrupts used as High Priority. I tested it with TMR0 and TMR2 only. The mechanics work, so I assume all Interrupts will work. Try it and let me know if something isn't working properly. I find it curious that I had to add ".txt" to get this forum to accept it as a valid upload! Remove the .txt to use it.
    DT_INTS-Q43.pbp.txt
    OK
    Default Re: PIC18FxxQ43 Version of DT_INTS
    I forgot to mention, the PIC18F27_47_57Q43.PBPINC files incorrectly list BANK36 with the same address range as BANK26. Remove the .txt from the attached file name and include the appropriate file in your project folder. PBP will look for it in the project folder first, then the C:// last. Since there is no BANK36 in the smaller 25_26_45_46_55_56Q43 chips, they are good to go. Charles assures me that that is what he received from Microchip and it wasn't a mistake copying from the Data Sheet.
    PIC18F27Q43.PBPINC.txt
    PIC18F47Q43.PBPINC.txt
    PIC18F57Q43.PBPINC.txt
    Apr 2003
    Cambridge - UK
    I put a copy of this in the User Example code area
    http://www.picbasic.co.uk/forum/content.php?r=71
    though it might be better in the DT Book of interrupts micro site
    http://dt.picbasic.co.uk/
    Lester - Forum Administrator
    www.crownhill.co.uk
    OK
    Crap! It was pointed out by tumbleweed on the ME Labs site that the ACCESS BANK is BANK5, not BANK4. I made that and a few other changes and have a revised version with an appended _1 in the name.
    DT_INTS-Q43_1.pbp.txt
    Feb 2012
    PERTH AUSTRALIA
    thanks mike
    your efforts on this is very much appriciated
    cheers
    sheldon
    Feb 2012
    PERTH AUSTRALIA
    Default Re: PIC18FxxQ43 Version of DT_INTS - UPDATE V3.42
    hI GUYS
    with Help from both Mike and Tubbleweed , an updated version of DT_INTs _Q43 has been done
    This version is only for use on the Q43 chip as it now requires Q43's feature that saves/ restores the INTs priority using its internal stack , not varables previously provided in the DT_ints include
    Please refer to the version notes in the attached file
    this inlcude is in Code under test uses the following high / low priorty interupts for my code for the following INTs for information
    tested using PBP3.1.5 for compile
    HIgh priority
    Timer 1
    Timer 2
    Timer 3
    Low priorty
    Timer 0
    IOC Int - portb
    U2 INt ( inputs
    if you find errors please post
    Sheldon
    Feb 2012
    PERTH AUSTRALIA
    Hi guys
    finally got the samples of 18f47q43 and mounted on the pcb i have
    starting to test the ints_18_q43 version
    i am doing a test on the timer0 as a high priority and then as a low priority
    set as a high priory timer0 works
    but set as low priority the chip crashes
    compiles ok and asm looks good to generate the priority levels
    mike can you see if you see something i have done incorrectly in the include
    i am wondering if the fast register save is affecting the re-enter_lp.bas include
    Aug 2011
    Could be, but I don't have any PBP version even remotely up to date to test it with.
    Could you post the .lst and .hex files that go along with that?
    One thing I never see... the INTCON0.GIE bit needs to be set, and I only see that happening if there's a high-priority intr defined.
    you can't have just a low-priority interrupt. If GIE = 0 then all interrupts are shut off.
    Feb 2012
    PERTH AUSTRALIA
    part of asm listing
    have included the hex and list files
     C:\USERS\SMW OFFICE\DOCUMENTS\MY PIC PROJECTS\K9 GTS PROJECT\PIC BASIC CODE\WORKING FILES\K9 LED CONTROLLER\VER 1.0 PCB\VER 1.3 DEV\LED DISPLAY BASE\DT_INTS-18_Q43.BAS	00678	ASM
    	ASM?
    INT_CREATE_L  macro
      local OverCREATE
        goto OverCREATE
        ifdef USE_LOWPRIORITY
            if (USE_LOWPRIORITY != 1)
           error "'DEFINE USE_LOWPRIORITY 1' required for Low Priority Interrupts"
    Priority = L
    INT_ENTRY_L
      bcf      _InHPint, 0
    List_Start_L
      clrf  BSR
    PREV_BANK = 5
     RETFIE  1
        bcf      _Serviced_L, 0
        ifdef INT_LIST_L
            INT_LIST_L                  ; Expand the users list of HP INT handlers
            error "INT_CREATE_L - INT_LIST_L not defined, can not create"
        btfsc    _Serviced_L, 0         ; if anything was serviced
        goto     List_Start_L           ; go around, and check again
        ifdef ReEnterLPused             ; was ReEnterPBP-18LP.bas included
            GetAddress21  INT_EXIT_L, RetAddrL
            L?GOTO   _RestorePBP_L      ; Restore PBP system Vars
    INT_EXIT_L
    PREV_BANK = 5
        retfie   FAST                    ; Return from Interrupt
    OverCREATE
        bsf  INTCON0, IPEN_INTCON0, 0 ; Enable Interrupt Priorities
        bsf   INTCON0,GIEL, 0         ; Enable Low Priority Interrupts
    	ENDASM?
    Aug 2011
    I don't see anything wrong with ReEnterPBP-18LP.bas, but there are a few other things I noticed.
    First off, as I said, you can't have just a low-priority interrupt.
    If you don't define a high-priority one then INTCON0.GIE never gets set, and if GIE is 0 then you get no interrupts period.
    If you only have one interrupt it must be high-priority.
    Next, there's an issue with the INT_ENABLE macro.
    The lines that setup the priority bits in the IRPx registers assume that the registers are in the access bank, and they're not.
    if (Priority == H)
        bsf  INT_Priority_Reg, INT_Priority_Bit, 0
        if (Priority == L)
            bcf  INT_Priority_Reg, INT_Priority_Bit, 0
    The ", 0" at the end of those lines tell the assembler to use the access bank instead of the BSR bank select register.
    In the Q43, the IRP registers are in bank 3, so they can't use the SFR access bank (bank 4).
    Those instructions need a BANKSEL before them, remove the ", 0", and don't forget to put the BSR register back afterwards.
    Something like this ought to work...
    if (INT_Priority_Reg != -1)
        if (Priority == H)
            movf BSR, 0			; save current BSR in WREG
    	banksel INT_Priority_Reg
            movwf BSR           ; restore BSR
            if (Priority == L)
                error "INT_ENABLE - Invalid Priority Specified"
    Finally, in the INT_CREATE_H macro, the line following OverCREATE comments out PEIE... that should be uncommented.
    Otherwise, if you're not using priorities you'll never get a peripheral interrupt.
    OverCREATE
        bsf   INTCON0,GIE, 0             ; Enable High Priority Interrupts
    ;    bsf   INTCON0,PEIE, 0            ; Enable Peripheral Interrupts
    should be:
    OverCREATE
    Feb 2012
    PERTH AUSTRALIA
    thanks tumbleweed
    ill put those changes in and test
    i will put timer1 as high and timer0 as low , as per what i actually need , in the end code
    this test will use 6 interrupts timer0-timer3, IOC , Usart2 and i am finding k40 hangover settings that i did change over still
    ill place an updated int-18_q43 include as tests complete
    cheers
    sheldon
    Feb 2012
    PERTH AUSTRALIA
    here is the modified include q43 ints code with tumbleweeds fixes to the high /low priority
    version code 3.43 -
    tumbleweed please check that the changes have been done correctly
    testing continues tomorrow
    cheers
    sheldon
    Feb 2012
    PERTH AUSTRALIA
    you get a compile error if this is not commented out
    there is no PEIE flag in INTCON0
    only IPEN
    remove comment out
    Aug 2011
    Oops, that one's on me! I forgot that they re-arranged things with the new VIC module and there's only GIE/GIEH and GIEL.
    You can just kill that line.
    I'm gonna have to take a closer look at the files you sent.
    There's no code getting into the output file for the low-priority stuff...
    Aug 2011
    In your main file you need to uncomment the 'define use_lowpriority' and rearrange the DT-INTS setup section.
    Try:
       ' ---------- Set up DT_INTS-18 Routine for Instant Interrupt handling   -----------
       DEFINE USE_LOWPRIORITY  1   ' Include if using Low Pr. PBP INTS
       ' ****** include Placed here becuase of pin varables and routine varable needed to be set first  *******
       INCLUDE "DT_INTS-18_Q43.bas"                  ; Base Interrupt System for 18FxxQ43 processors  ( DT_INTS-18_3_42.BAS)
       INCLUDE "ReEnterPBP-18.bas"                   ; Include if using PBP interrupts
       INCLUDE "ReEnterPBP-18LP.bas"                 ; Include if using Low Priority PBP INTS
      INCLUDE "modedefs.bas"                        ' Required for shiftout,shiftin commands as defined symbols
     ;----[High Priority Interrupts]-----------------------------------------------
    INT_LIST macro	; IntSource,         Label, Type, ResetFlag?
       INT_Handler TMR1_INT, _EL_ClockCount,PBP,yes      ; Call ClockCount  subroutine in K9_Elapsed_INT-18.bas
    ;   INT_Handler TMR3_INT, _Show_Display, PBP,yes      ; Call Display Show for LED Modules in
    ;   INT_Handler TMR2_INT, _Bright_Ctrl,  PBP,yes      ; call Brightness Control for display module
     INT_CREATE				; Creates the High Priority interrupt processor
    ;----[Low Priority Interrupts]------------------------------------------------
    INT_LIST_L  macro  ; IntSource,        Label,  Type, ResetFlag?
       INT_Handler TMR0_INT, _Timer0_Count, PBP,yes      ; call Timer0_Count subroutine
    ;   INT_Handler  IOC_INT, _Rx_mode_IOC,  PBP,yes      ; Call Rx_mode_IOC subroutine for RF RX_mode
    ;   INT_Handler  U2_INT,  _Term_RX,      PBP,yes      ; Q43 - Call Term_input for terminal char buffer
      ; INT_Handler  RX2_INT, _Term_RX,      PBP,yes      ; K40 - Call Term_input for terminal char buffer
     INT_CREATE_L                            ; Creates the Low Priority interrupt processor
    Feb 2012
    PERTH AUSTRALIA
    sorry tubbleweed for the confusion ,
    i had uncommented all the low priority commands required and tested for the failure
    but then re removed the low priority for checking it worked , then sent the files ,
    put it down to being 1AM when i was doing the changes
    here is the files with the low priority commands in place and the files results
    cheers
    sheldon
    Aug 2011
    From what I can tell the basic interrupt structure looks to be ok.
    Unfortunately, the way the various files are written, all of the ReEnterPBP routines don't appear in the .lst files, so it makes tracking what they're doing next to impossible.
    When you have ReEnterPBP-18 and ReEnterPBP-18LP together they use a boatload of ram, over 136 bytes for the PBP context.
    That puts many of the variables outside the access bank, so it's possible there's a bank select issue in there somewhere.
    Feb 2012
    PERTH AUSTRALIA
    i am finding some other issues with bank access with other asm code i have , that is not happy on q43
    thinking that what you did with
    movf BSR, 0
    movwf BSR
    historic code i use for elasped timer to get the cycles constant and limited may now work against q43 chip ??
    i may be wrong as my asm really sucks but each command that has BCF will need a banksel , bsf ????
    having trouble with load of timer1 using asm on the q43
    but doing that change would add cycles i am sure
    i hope i am wrong
                                     ; 16.368mhz tcxo = 61.0948ns clock       16.00Mhz = 62.5 ( internal osc used currenlty 20/2/20)
    TimerConst = 40912               ; 40912 + 8 cycle instrution load = 40920 x 61.0948ns = 2.499999216mS  timer 1 clock tick   (  16mhz int = 39992 + 8cycle = 40000 x 62.5ns = 2.5ms)
    TimerConst = 65536 - TimerConst  ; set value for timer1 preload
    ;-----------------  ADD TimerConst to TMR1H:TMR1L -------------------------
    ADD2_TIMER   macro
         BCF     T1CON,TMR1ON, 0       ;  1 Turn off timer
         MOVLW   LOW(TimerConst)       ;  1
         ADDWF   TMR1L,F, 0            ;  1
         BTFSC   STATUS,C              ;  1/2
         INCF    TMR1H,F, 0            ;  1
         MOVLW   HIGH(TimerConst)      ;  1
         ADDWF   TMR1H,F, 0            ;  1
    ; -----------------  ADD TimerConst to TMR1H:TMR1L and restart TIMER1 ------
    RELOAD_TIMER  macro
         ADD2_TIMER
         BSF     T1CON,TMR1ON, 0       ;  1   Turn TIMER1 back on  (8 cycles)
    ; -----------------  Load TimerConst into TMR1H:TMR1L ----------------------
    LOAD_TIMER  macro
         MOVE?CT  0, T1CON,TMR1ON
         MOVE?CB  0, TMR1L
         MOVE?CB  0, TMR1H
         ADD2_TIMER
    Feb 2012
    PERTH AUSTRALIA
    mmm well still a problem for low priority interrupts
    if low priority interrupt are enable, it stops devices on high priority as well
    see attached code for test
  1. Replies: 2
    Last Post: - 31st October 2017, 18:04
  2. New PBP version - Gold version - Is it really worth it?
    By financecatalyst in forum General
    Last Post: - 8th October 2011, 02:34
  3. help with version 2.04
    By mxjf in forum mel PIC BASIC Pro
    Last Post: - 13th October 2006, 05:01
  4. New Version
    By mslaney in forum PBP Wish List
    Last Post: - 25th January 2005, 09:06
  5. Shall we see a new version soon?
    By Bulman in forum mel PIC BASIC Pro
    Last Post: - 28th September 2004, 17:18
