I2C read and write to 24C01 eeprom
Results 1 to 8 of 8
    Jun 2013
    Default I2C read and write to 24C01 eeprom
    I and difficulty reading and write to the eeprom,the reading instruction I used is
    I2Cread SDA,SCL,$A0,$00,[data1.......data7]
    I2Cwrite SDA,SCL,$A0,$00,[data1......data7]
    all data are define as word variable
    I'm not sure it have written into the memory correctly or not,but the value of data1 can read into data3 and data2 value can read in data5
    I have check with a oscilloscope using I2C analysis,trigger on missing acknowledge signal all data return no acknowledgement
    have I did something wrong?
    Quebec, Canada
    Default Re: I2C read and write to 24C01 eeprom
    From the manual, p. 158:
    The Address size sent (byte or word) is determined by the size of the variable that is used. If a byte-sized variable is used for the Address, an 8-bit address is sent. If a word-sized variable is used, a 16-bit address is sent. Be sure to use the proper sized variable for the device you wish to communicate with. Constants should not be used for the Address as the size can vary dependent on the size of the constant. Also, expressions should not be used as they can cause an improper Address size to be sent.
    Oct 2009
    If using bytes then the format would be something like
    I2CWRITE SDApin,SCLpin,$A0,$00,[data1,data2,... etc etc]
    If using word variables the format would be something like this
    I2CWRITE SDApin,SCLpin,$A0,$00,[data1.lowbyte,data1.highbyte, data2.lowbyte,data2.highbyte, etc etc]
    IC2READ would have the corresponding values in its statement
    you don't say what chip/osc you are using , consider this
    The timing of the I2c
    instructions is set so that standard speed devices(100kHz) will
    be accessible at clock speeds up to 8MHz. Fast mode devices (400kHz) may be
    used up to 20MHz. If it is desired to access a standard speed device at above
    8MHz, the following DEFINE should be added to the program:
    DEFINE I2C_SLOW 1
    also read the data sheet for your eprom re
    1. address command size
    2 page size
    writes that exceed a page in size or cross a page boundary can go wrong
    read the manual and watch out for common myths
    Oct 2009
    Richard, I was using the OP's example hence the address, and trying to explain that as a word variable he needed to write the high and low bytes. It was not meant as an optimised example...
    I used the following to send word variable values to a PCA chip.. it might not be tight code, it may not be "as it should" in the eyes of more experienced programmers, or it may not follow convention in the manual... But it works
        pcaChannel = 1
        i2cControl = $6 + 4*pcaChannel
        I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[0,0,CH2_PWM.lowbyte,CH2_PWM.highbyte]
    Quote Originally Posted by Scampy View Post
    making a special case where endianness needs to be managed.
    the pca chip requires the data sent low byte first, i2cread/write natively send high byte first.
    to do that for a eprom is just a typing exercise
  1. I2C eeprom read write
    Last Post: - 14th July 2010, 17:49
  2. How to Read / Write I2c 24LC16B EEprom
    By odie52 in forum mel PIC BASIC Pro
    Last Post: - 5th May 2010, 03:00
  3. read/write eeprom
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 01:17
  4. I2C Read and Write
    By DerekMacom in forum mel PIC BASIC
    Last Post: - 21st April 2008, 15:44
  5. Write and Read from eeprom
    Last Post: - 9th June 2007, 14:56
