NCO Calculator
Results 1 to 25 of 25
Thread: NCO Calculator
    Aug 2005
    Michigan, USA
    Default Re: NCO Calculator
    Isn't easier all these calculation done in a Excel file?
    A spreadsheet is easier to make but I don't think it's easier to use. Mike's stand-alone app' is a seriously cool accomplishment. Personally, I'd rather use a small stand-alone app' instead of a spreadsheet.
    Many years ago I built an SPBRG Calculator spreadsheet followed by an SPBRG Calculator app' written in JustBASIC. I much prefer using the app'.
    Cheerful regards, Mike, K8LH
    Name:  K8LH SPBRG Calc.png
    if only pbp was still being kept relevant, all these things and more are built into mplabx and easy to use
    OK
    I forced myself to work with MPLABX over the past few days. I needed a combination of features only found in the PIC16F18426, which is too new for PBP3. I'm building the software in ASM using MPLABX. I like the Debug feature. As I'm not that familiar with ASM, the Debug showed me where I got stuck in an endless loop and helped me catch a few other problems in my code. It's taking me about 10X longer in ASM than it would in PBP3, but I'm learning a bunch through the experience.
    You are a herο! Two times, for ASM and MPLABX!
    I started using PIC with plain ASM coding but never go back again.
    Aug 2005
    Michigan, USA
    Anyone know if mpgmike ever fixed the errors and updated his nco calculator app'?
    OK
    No, I didn't.
    Aug 2005
    Michigan, USA
    No, I didn't.
    If it's not stepping on your toes, would you mind if I created a stand-alone NCO Calculator app', much like my SPBRG Calculator app'? I just need an accurate tool people can use on a couple upcoming retro computer projects.
    TIA... Cheerful regards, Mike, K8LH
  1. help with calculator
    By minssss in forum General
    Last Post: - 10th November 2009, 00:12
  2. Calculator LCD
    By menze in forum General
    Last Post: - 26th June 2006, 21:31
  3. help with my calculator project
    By loayaouad in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 07:42
  4. Calculatorīs LCD
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 4th May 2005, 10:27
  5. Calculator
    By neiron21 in forum mel PIC BASIC Pro
    Last Post: - 1st February 2005, 00:53
