Problem with a program...
Results 1 to 7 of 7
    Question
    Are you rotating the encoder for all six seconds? If you only rotate it while counting pulses on PortB.7, you will miss the pulses on portB.6.
    Thumbs down With a little help from the manual ...
    You're right, ingvar ...
    as PBP can't do two things at a time ...it reads Portb.7 for 3 seconds and THEN Portb.6 for the 3 following seconds ...
    No hope this way ...
    hawk72501's Avatar
    hawk72501 Guest
    Ingavr and acetronics thanks for replying!Have you any idea how to make it working to count simultaneously the 2 channels?
    Mister_e thanks for replying.If i use a pull-up resistor of 2.7K is that ok?Should i turn the internal pull-ups off?
    Wink
    Hi Hawk,
    another thread is still open on this subject ... SEARCH function !!!
    11 results ... no less !!!
    COUNT is not design to count on 2 pin at the time. You can use Interrupt on PORTB change. Once in the interrupt routine, read the whole PORTB, keep only the upper bit and see wich is LOW, increment a counter variable and TADA.
    OR without interrupt routine, poll the interrupt flag and do the same as above.
    HTH
  1. Simple program - Strange problem!
    Last Post: - 19th December 2009, 22:52
  2. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 17:01
  3. Making Program Code Space your playground...
  4. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 20:17
  5. serial program and sensor problem
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2006, 04:16
