FREQOUT 4mhz
Results 1 to 21 of 21
Thread: FREQOUT 4mhz
    Oct 2009
    Default Re: FREQOUT 4mhz
    If its one of those small 3v - 15v type piezo buzzers then this can be driven directly from the PIC
    Some further examples and reading http://www.picbasic.co.uk/forum/showthread.php?t=3076
    Can't really help with the frequency part, the buzzer I use as an alarm just runs at whatever its internal frequency is when DC voltage is applied
    It's not a buzzer, it's just a transducer. And like I say, FREQOUT (according to manual) is limited at 4mhz and would like to know more.
    Ok -- good link -- I'll try the PWM command instead.
    OK
    I seem to recall the FREQOUT command is only accurate at 4 MHz. If you're clocking at 8 MHz, divide the value by 2 (and so forth). The command itself should work at any clock speed. Just take into account any divisor needed to achieve your 6500 Hz.
    If you have Mister E PIC Multi-Calc, you can use the Timer Helper to create any frequency the processor is capable of, and at any chosen Fosc.
    From the manual:
    FREQOUT works best with a 20MHz or 40MHz oscillator. It can also work with a
    10MHz or 8MHz oscillator and even at 4MHz, although it will start to get very hard
    to filter and be of fairly low amplitude. Any other frequency will cause FREQOUT to
    generate a frequency that is a ratio of the actual oscillator used and 20MHz.
    For simple beep type of tone from a piezo buzzer just use PWM, HPWM or "manually" run the (E)CCP module.
    Aug 2003
    FREQOUT can do dual frequency (polyphonic), and that is a mess at 4MHz.
    DTMF works the same way, but I’ve never had a telephony system understand it for a pic clocked less than 20MHz, no matter what I do.
    For a single frequency it might be ok, but as said, PWM is non-blocking, can make the sound forever, and a much better choice for a single audio freq.
    I may have to use PWM as it appears FREQOUT won't function with my antique 16C72. (I have a boatload of them).
    The 16C72 is 8bit.
    We'll see -- thanks -- will get back to you no doubt.
    Also using a 2N4401 to drive the piezo, would imagine I need it ?
  1. FREQOUT command
    By Art in forum mel PIC BASIC Pro
    Last Post: - 8th February 2015, 07:21
  2. Freqout ? ? ?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 01:39
  3. bootloader Freqout problems
    By handgio in forum mel PIC BASIC Pro
    Last Post: - 5th December 2007, 14:38
  4. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 00:51
  5. FREQOUT delays
    Last Post: - 7th December 2003, 00:49
