PIC18F1320 HPWM on 2 pins
Results 1 to 22 of 22
    Jan 2008
    Selm, Germany
    Default Re: PIC18F1320 HPWM on 2 pins
    Hello Richard,
    Iīm using an old PC that runs XP Professional.
    MPLAB IDE v 7.61
    Microcode Studio 3.0.0.5
    Compiler Picbasic Pro 2.50C
    Programmer PICKIT2 and 3
    Complete Code:
    '* Name : AnalogDEBUG *
    '* Author : [Davidpower] *
    '* [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 05.12.2017 *
    '* Version : 1.0 *
    '* Notes : 16F88 no LCD *
    '* : Portb.7 analog IN 0-5V *
    Include "modedefs.bas"
    Define OSC 4
    Define ADC_BITS 4 ' Set number of bits in result
    Define ADC_SAMPLEUS 50 ' Set sampling time in uSec
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 2
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_Mode 0
    DEFINE DEBUG_PACING 1000
    CMCON = 7 ' Disable analog comparator
    ANSEL = %01000000 ' set AN6 (RB7) as analog, others to digital
    ADCON1.7 = 1 '
    GLCDBM VAR WORD
    PAUSE 1000 ' lcd settle time
    DEBUG 10,13
    loop:
    ADCIN 6,GLCDBM ' Read channel 6 (RB7)
    DEBUG "*.*",DEC5 GLCDBM,13,10
    Goto loop
    The DEBUG line gives the compiling error "bad expression"
    If I use for example :
    DEBUG GLCDBM
    then no compiling error shows up. Doesnīt mean that it works.
    Jan 2008
    Selm, Germany
    Hello Richard,
    to be shure I ordered PBP3 Gold and Microcode studio 5.0 today. Will see if that helps. One question: What Computer do I need for that software?
    Mugel
    Oct 2009
    I copied the code in post #16 into microcode studio version 4.0.0.0, selecting 16F88 in the drop down menu and clicked on compile and it compiled using PBP 2.60c with MPSAM 5.06 with no errors
    The only change I had to make was change LOOP to MAIN for the main program loop
    '* Version : 1.0 *
    Define OSC 4
    DEFINE DEBUG_BIT 2
    DEFINE DEBUG_Mode 0
    ADCON1.7 = 1 '
    GLCDBM VAR WORD
    DEBUG 10,13
    Goto main
    Mugel if you could use the code tags to insert code it makes the post easier to read ( use [ code ] insert your code here [ / code ] - remove the spaces between square brackets and code)
    Not sure if the code works as it should, but thought I would see if it compiled on an version 2.60 with an old copy of MPSAM...
  1. PIC18F1320 Config Help
    Last Post: - 8th June 2013, 07:31
  2. Timer 3 config for HPWM using remappable pins
    By jimbostlawrence in forum General
    Last Post: - 5th December 2012, 15:26
  3. PIC - 8 Pins - 6 Output Pins ?
    By DanPBP in forum Off Topic
    Last Post: - 22nd October 2007, 01:23
  4. Setting up 5 HPWM pins on 18F4680
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2006, 06:54
  5. Compiling error with PIC18F1320
    By mazlan in forum mel PIC BASIC Pro
    Last Post: - 26th November 2004, 02:01
