PIC18F1320 HPWM on 2 pins
Results 1 to 22 of 22
    Default Re: PIC18F1320 HPWM on 2 pins
    DEFINE DEBUG_Mode 0
    IS INCORRECT and simply won't do anything
    pbp defines must be uppercase
    try it this way tx:-
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_BAUD 9600
    DEBUG "*.*",DEC5 GLCDBM ,13,10
    rx
    SERIN2 PORTC.7,84,[ WAIT("*.*") , DEC RX] ;
    if this is still your goal
    So I guess its waaaay easier to use two
    PICs than to scramble everything in just one
    then you are sadly misguided , its never easier . get a better chip that's way easier
    if your goal is different why not start a more relevant thread
    either way post your latest code
    Jan 2008
    Selm, Germany
    Hello Richard,
    thank you for your fast answer.
    I Know about the upper case sensitivity of Defines but it was obviously too late yesterday.
    Didnīt know DEBUG and SERIN2 can be mixed.
    I always thought how would one PIC know when to receive without handshake. Tried HSERIN for that with the RX and TX lines.
    Didnīt work of course althoug both PICs have a USART.
    Will try that at home this evening because its about noon by now and Iīm at work. Nothing with PICs, just metal and engines.
    regards
    Mugel
    Jan 2008
    Selm, Germany
    Lightbulb Re: PIC18F1320 HPWM on 2 pins
    Hello Richard,
    by using the right PIC you may think of something like this:
    http://www.microchip.com/wwwproducts/en/PIC16F15323
    I donīt believe PBP supports that one or similar new ones.
    Iīm shure with 10 (or 30) more IQ points I could program an older one thats supported by PBP
    but Iīm stuck to my own miserable brain.
    regards
    Mugel
    Actually Mugel, PBP3.1 does support the PIC16F15323. At the cost of a few extra pins might I suggest something like the PIC18F26K22. It has 2 USART ports and can run @64Hhz.
    EN82fn
    Jan 2008
    Selm, Germany
    ahhh,
    you are trying to talk me weak for buying PBP3?
    may work......
    Jan 2008
    Selm, Germany
    Hello Richard,
    i tried your example and i get compilation error "DEBUG " bad expression or "SERIN2 bad expression"
    I even used a PBP example that was delivered with my software and I get the same "HSERIN bad expression" compilation error.
    So I have a software problem but I donīt know where to search.
    a totally meaningless statement
    you need to post the complete code you are trying , also state the version of pbp you are using
    Jan 2008
    Selm, Germany
    Hello Richard,
    Iīm using an old PC that runs XP Professional.
    MPLAB IDE v 7.61
    Microcode Studio 3.0.0.5
    Compiler Picbasic Pro 2.50C
    Programmer PICKIT2 and 3
    Complete Code:
    '* Name : AnalogDEBUG *
    '* Author : [Davidpower] *
    '* [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 05.12.2017 *
    '* Version : 1.0 *
    '* Notes : 16F88 no LCD *
    '* : Portb.7 analog IN 0-5V *
    Include "modedefs.bas"
    Define OSC 4
    Define ADC_BITS 4 ' Set number of bits in result
    Define ADC_SAMPLEUS 50 ' Set sampling time in uSec
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 2
    DEFINE DEBUG_Mode 0
    DEFINE DEBUG_PACING 1000
    CMCON = 7 ' Disable analog comparator
    ANSEL = %01000000 ' set AN6 (RB7) as analog, others to digital
    ADCON1.7 = 1 '
    GLCDBM VAR WORD
    PAUSE 1000 ' lcd settle time
    DEBUG 10,13
    loop:
    ADCIN 6,GLCDBM ' Read channel 6 (RB7)
    DEBUG "*.*",DEC5 GLCDBM,13,10
    Goto loop
    The DEBUG line gives the compiling error "bad expression"
    If I use for example :
    DEBUG GLCDBM
    then no compiling error shows up. Doesnīt mean that it works.
  1. PIC18F1320 Config Help
    Last Post: - 8th June 2013, 06:31
  2. Timer 3 config for HPWM using remappable pins
    By jimbostlawrence in forum General
    Last Post: - 5th December 2012, 14:26
  3. PIC - 8 Pins - 6 Output Pins ?
    By DanPBP in forum Off Topic
    Last Post: - 22nd October 2007, 00:23
  4. Setting up 5 HPWM pins on 18F4680
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2006, 05:54
  5. Compiling error with PIC18F1320
    By mazlan in forum mel PIC BASIC Pro
    Last Post: - 26th November 2004, 01:01
