LCD BARgraphs
Results 1 to 40 of 233
Thread: LCD BARgraphs
    Mar 2008
    Hello !
    First of all , thanks for the LCD codes.
    I applied the code below , it works fine ; but at the first row ; " Value= XXX " always flickering ; like something is writing over the " Value = XXXX " and it's always flickering.
    What is the problem ?
    @ DEVICE pic16F877
    @ DEVICE pic16F877, WDT_on
    @ DEVICE pic16F877, PWRT_ON
    @ DEVICE pic16F877, PROTECT_OFF
    @ DEVICE pic16F877, HS_OSC
    TRISA=%00000001
    TRISB=0
    TRISE=0
    INCLUDE "LCDbar_INC.bas"
    ham var word
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 0
    DEFINE LCD_RWREG PORTE
    DEFINE LCD_RWBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1000
    DEFINE LCD_DATAUS 225
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 100
    ADCON1=%10001110
    LOW PORTE.2
    LCDOUT $FE,1
    PAUSE 200
    Loop1:
        ADCIN  0, ham
        ham=1023-ham
        LCDOUT $FE,2,"Value = ",DEC ham,"   "
        ; syntax- BARgraph   Value, Row, Col, Width, Range, Style
        @         BARgraph  _ham,   2,   0,    16,   1023,  lines
        PAUSE 50
    Goto Loop1
    Quote Originally Posted by karamastik View Post
    Loop1:
        ADCIN  0, ham
        ham=1023-ham
        PAUSE 50
    Goto Loop1
    That's because something is always overwriting Value = XXXX. VALUE = XXXX is always overwriting VALUE = XXXX.
    Try ONLY overwriting just the value not the whole string.
    Pause 50 is a bit low, try to increase it a little bit more.
    karamastik,
    LCD_COMMANDUS 1000 seems a little low.
    On most displays, the Home command ($FE,2) takes 1.6ms or 1600us.
    Try increasing it to 2000, some displays need even more than that.
    LCD_DATAUS 225 is pretty High. Should be around 50.
    If this one is too high, it won't cause a problem. It'll just slow things down unnecessarily.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
